I have a 42" Sony
I have a 42" Sony MBT-XBR 900 plasma flat screen that recently developed a 1 inch wide vertical line that goes from the top to the bottom of the screen about 1/4 of the way from the left side of the unit. When watching TV, there's a tiny bit of snow that comes through. In DVD mode, it's totally black. Any idea what the problem is, and what it might cost to fix? Thanks.
  • 1 more comment
  • petermedvin Nov 21, 2008
    Thanks. How do I fix this and what might it cost?
    Any idea about how much?  If it's going to cost me $400-$500 to get this done, I may be better off buying a new set, prices being what they are...
    I'll try to dig out the user manual. Do other folks agree that this is probably a home fix?
  • 76 Answers
Whether it is a home fix, depends on your level of expertise. if you are ok with following some of the advice here, and are accustomed to this, then go for it. otherwise, recycle the unit
Posted on Nov 21, 2008
  • 685 Answers
Http://akamaipix.crutchfield.com/Manuals/700/70042XB900.PDF here is a copy of the owners manual i hope this will help you.as i was looking for it i also looked up some prices it will cost you anywhere between 200 to 300 dollars to fix.http://www.crutchfield.com/p_70042XB900/Sony-KE-42XBR900.html?tp=161&omnews=2566039 here is a direct link to there site also so you can explore it for your self.
    Genius:
  • 1,550 Answers
This cant be fixed by reset method and it cant either be fixed at home .
It will cost you around $300-400 to get it repaired .
You need to replace the chip .
In order to get correct quotation you call sony service center .
    Sergeant:
    Champion:
  • 435 Answers
Did you try hard reset through OSD settings ?
  • 10,594 Answers
You need service manual to diagnose problem board.
It would be better to get new LCD TV instead of to repair Plasma. Please ask Sony Sales store for exchange this TV with LCD as they might have scheme.
Good Luck.
  • 4,806 Answers
This sounds more like the horizontal possitioning has changed, "snow in TV mode" and "black stripe in DVD mode" you should be able to adjust these using the user manual and cost nothing to put right. get the user manual reset the tv to factory settings that should do the trick!!
regards
  • Lee Hodgson
    Lee Hodgson Nov 21, 2008
    there is also a quick troubleshooting guide here:
    http://esupport.sony.com/US/perl/model-h...
    regards
  • Lee Hodgson
    its worth a try for nothing, troubleshooting the tv first to rule out other possibilities is always a good thing to do, the manuals can be a good source of information when a "glitch" happends on the system and refering to these can resolve many problems without paying a hefty price for servicing.
    Sony only give limited info out ot the websites, so a good idea would be to phone them if all else fails
    regards
    Sergeant:
  • 276 Answers
Its the problem of the faulty ic on the main board.
  • smarttech Nov 21, 2008
    the cost will be negligible and many of the times its covered under service charge of a technician.near about 75$ to 100$ as per the engineer charges.
    thanks
    no it will cost not more then 100$.
    thanks.
  • 19,396 Answers
That is either a faulty sustain board or a faulty chip on cable inside the tv.
  • 1 more comment
  • Ginko
    Ginko Nov 21, 2008
    There is no faulty IC on the main board.
    The most common cause is a faulty built-in chip on cable technology. The ribbon cable that connects to the plasma screen has a built in chip to encode the signal, when the chip is faulty, you get either a thick black band, or the screen is black from the point where the cable connects to the screen.
    You find out if it is the cable because you will see that the area with no raster on the screen will start fron the point where the cable hooks up.
    Sometimes a faulty sustain board can give you same problem, in this case you will see the area with no signal in correspondence to sustain board location.
    To fix this the TV must be taken apart, and being it a delicate and expensive set, it is always better having the job done by a technician.
    Both the cable and sustain board are not expensive parts.
  • Ginko
    Ginko Nov 21, 2008
    About the repair.
    Check this picture:
    What you see in the picture are the flex cables at the bottom of the plasma screen, if one of them is defective you get this problem.
    The repair should be a $80/$120 fee for the labor plus the part price, let say that it should go around $200 if it is one of the flex cable, and up to about $400 if it is some other problem, if the whole plasma screen is defective it will be above $500, but this is rather unlikely.
    The best thing to do is ringing Sony and asking a prheventive quote on the repair. You can also ask them the terms for a warranty extension.
    A warranty extension is usually cheaper than a single repair and will cover your TV for 3 extra years.
    Here is an example of warranty extension, call Sony or call a dealer to find a warranty extension package that applies to your TV set: Sony Upg Warranty 3YR Total Depot SVC Plasma ...
  • Ginko
    Ginko Nov 21, 2008
    I am not just another guy, and I am telling that unless you fix this with an hard reset by leaving the TV unplugged, this is not going to be a home fix.
    You have two professional technicians in here, the other one is welcomejee, that works in a TV repair workshop, the rest of the comments are coming from user levels that are just sharing their personal opinions or trying to use some common sense.
What causes vertical lines across the screen?
Lines across the screen is mainly caused by a display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 18, 2016 | Sony Televison & Video
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Random 3'' vertical red line on 42'' Hitachi Plasma TV
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
Jan 15, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Sony TV problem
sounds like a power control board related problem i would leave this one to the experts.
A thermo fuse I doubt it. you dont have a temperature control type problem but a power distibution problem seems more realistic.
Dec 14, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
BLUE VERTICAL LINE
The address module that is at the bottom of the PDP in that location is the suspect and the cheapest repair. There is usually 3 to 4 modules at the bottom of the PDP and each one addresses information vertically. If it were just one pixe wide then the PDP would be bad.
Jun 07, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
