Pellet stove probably the auger as it lights and goes out again do to not enough pellet feed plus auger makes a loud whining noise
  • bigjohn04 Nov 21, 2008
    The stove is a Breckwell And the only model info I can find Is model (The Big E) no number is mentioned
    Master:
  • 638 Answers
Sending u the brekwell website link for manual download
Posted on Nov 21, 2008
    Sergeant:
  • 276 Answers
Can i have the exact model number so as to help u,
Stove will run for 5 to 15 mins and the auger will stop feeding.
Are the pellets getting stuck or jammed in the auger? Take a look at this website and perhaps it will give you some ideas to look at:
http://www.pelletstovefires.com/pellet-stove-problems.html
Nov 22, 2017 | Pool & Spa
No flame. The auger works fine and the pellets are feeding in. There is no fire to burn them.
Do you have a user's manual? Most pellet stoves need to be lit before starting the auger to sustain the fire.
Feb 10, 2017 | Cars & Trucks
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Making a noise in my pellet stove
Is the noise constant or intermittent? Constant will be a combustion blower that's bad. Intermittent is probably an auger on its way out.
Mar 17, 2014 | Pleasant Hearth Home
How do i fix ager on my pellet stove?
Hello Ethan, First I would uncouple and remove the auger motor from the auger shaft. Next turn the stove on to see if the auger motor turns. If it does turn, try to hold the motor shaft with your hand to determine if the motor has sufficient torque to turn the auger. If motor seems to be strong enough , use a pair of pliers or a vise grips and try to rotate the auger shaft. If the auger will not turn, it might be clogged up with pellets or pellet dust. The clog will have to be removed. If that is the case, I think the gears in the motor are stripped and a new motor is in order. Note: Damp pellets swell up and turn hard as concrete when they dry out.
Dec 06, 2013 | Home
Pinnacle Pellet stove augre gets stuck
hmm, could be low power to the motor, heavier power cord, or it's possible the auger needs new bushing/bearings, wiggle the auger to see if it has any play in it OR it's fussy about the size of pellets it made to feed. please send pictures and or results.
Jay
Jun 08, 2017 | Pool & Spa
I clean the stove as discribed in the tape i got w/ the unit. But, in about 8hrs. burn time , fire box is over full and feed tube is backed up. I have air wide open and lowest feed setting. Any ideas . If...
That is an old pellet stove. One problem may be that you have recently switched the type (Manufacturer) of pellets. Not all manufacturers make the pellets the same way. So you would have to re-tweek the auger feed an the air intake to the stove. If you no longer have your Owners Manual try searching Google for the Manufacturer and contact them for advice. But, I suspect that the model you have is no longer manufactured, as it does not meet the current EPA standards for emissions.
Jan 27, 2011 | Heating & Cooling
I have the same problem that bethanypitha has...the auger won't regulate the amount of pellets it spits out and they back up...even though the feed is turned all they way down
If you changed the brand of pellets that you normally had used, that may be the problem. Unfortunately, no two pellet manufacturers make their pellets the same way and the exact same size. You will need to tweek your stove to that brand of pellets. If you have your Owners Manual, look under Trouble Shooting and you'll probably find the answer. If not, contact the manufacturer of your pellet stove for more information.
Jan 25, 2011 | Heating & Cooling
Plugged feeder on pellet stove
if u can get at it you can clean it, if you get at a little of it you may be able to hit it with a small brush or paper clip or finish nail or whatever while it is revolving. I spraye my old stoves auger with PB blaster then cleaned it and of course let it air out for 2 days as that is flamable. The cause is probably inferior non-hardwood pellets. Been there....and doing that .. good luck
Dec 07, 2009 | Stoves Heating & Cooling
Pelpro pellet stove will not start. Press the start button, igniter button lights up but nothing happens.
Is the auger light coming on to and dropping pellets into the burn pot? If the auger light is not coming on, you probably have an issue with the board controlling it. If the auger light is coming on, and pellets are dropping into the burn pot and it is still not lighting, then you have only a few other possible problems.
1. The air damper is not allowing enough air in, so pull the damper rod out 1/8" increments until it lights.
2. Your ignitor is faulty and not producing enough heat to light the stove. You can either contact a local dealer and get a replacement ignitor, or you can manually light the stove with a special firestarting gel made for pellete stoves. When you press the start button look into the burn pot. If the ignitor isn't bright orange, you aren't getting enough heat from it.
Hope this helps...good luck.
Oct 11, 2009 | Coleman Dryers
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
