Question about Sewing Machines
Necchi 3205FA bobbin size?
I have read my manual, but I can't figure out what kind/size of bobbin I need for my Necchi 3205FA machine.
SOURCE: Have a Necchi 3205FA and
There is a serger attachment available for that model. When you attach it to the machine you must start the fabric from the top of the foot. The foot won't cut the fabric if you feed it under the foot. You will want to use the Wide zigzag, overlock, or hemstitch stitches. Set stitch length knob on #4 for overlock stitch #1-0 for hemstitch or zigzag. Set the stitch width to the maximum. Make sure the hook arm is inserted over the needle screw so that when the needle goes us and down the attachment will work. Start on the edge of your fabric by making a small cut about 1-2 cm deep and about the same distance from the edge as the cutting blade. This will make it much easier to feed the fabric over and then under the foot. Remember to start the fabric on top of the foot and then feed it under the foot before it reaches where the needle would penetrate.
Posted on Dec 06, 2008
Mimito7
  • 128 Answers
SOURCE: Necchi Heavy Duty Sewing machine model 3205FA,
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Posted on Apr 22, 2009
SOURCE: 6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Posted on May 06, 2009
  • 47 Answers
SOURCE: necchi sewing machine
www.ifixmachines.com has lots of parts fitted to your sewing machine for a cheaper price
Posted on Jul 23, 2009
  • 12 Answers
SOURCE: I need a user manual for a Necchi Alco 2200 sewing machine
Contact the individual who posted this answer.
Posted on Aug 20, 2009
Top thread too tight?
make sure tat the thread is between the tension plates and not behind and jamming on the bolt
proper tension is a slight resistance when you pull the thread to thread the needle
Oct 20, 2016 | Necchi Sewing Machines
Where cn i purchase a power cord and foot controller for a Necchi heavy duty model 3205 fa?
http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 29, 2015 | Necchi Sewing Machines
I have a Necchi 3205FA ROYAL series sewing machine. It will not sew at all the only time the needle moves is when I click the bobbin in and then it only moves for a second then stops completely.Should
Can you turn the handwheel manually? Does it move freely? If not, the machine needs to be oiled. Check the manual for the proper oiling locations. Basically, any metal to metal areas require oil. Just make sure the machine is unplugged and avoid oiling the motor.
Oct 13, 2014 | Sewing Machines
What Bobbin Style for Necchi 531FA
check with sewingpartsonline.com for a manual & the bobbins for the machine.
necchi's are a good reliable machines, I have 2 myself
one sewer to another
Jan 17, 2012 | Sewing Machines
Ned a diagram (or detailed instructions) on to thread a Necchi 3205FA & installing the bobbin. Thanks.
try www.sewusa.com there are threading diagrams for some Necchi models. even if yours isnt there the bobbin should be similar.
Sep 20, 2011 | Necchi 3101 Mechanical Sewing Machine
Hi - I'm in the market for a sewing machine. I'm trying to decide between a Singer 4832C or a Necchi 3205FA. Which would u recommend? Thx.
I used to sell necchi's, I have used necchi's for over 30 years for sewing & quiting. I own a necchi model 4595 mechanical sewing machine, & a omega by necchi, model 6150, electronic, my husband does his quiting on it.I have made clothes & quits on both machines
I have never sold or tried a necchi 3205fa or a singer 4832c
all I ever had were old singers, which I have gotten rid of all them
make sure it has a operation manual with it.
make sure you can take it back if something is wrong with it.
happy sewing
Jul 23, 2010 | Singer 7442 Mechanical Sewing Machine
The needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Jul 09, 2010 | Necchi Sewing Machines
Necchi Heavy Duty Sewing machine model 3205FA, bend needle while hemming denim skirt, replaced the needle, but now the needle is not picking up the bobbin thread, any suggestions for me to try???
Apr 20, 2009 | Sewing Machines
Sewing Machines Logo
79 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
