Question about Lexmark T632 Laser Printer
Lexmark T632 top tray is ejected when empty
3 universal paper trays are linked by paper type, size and color. When tray 3 (on the bottom) is selected as the default, the printer moves to tray 1 (top) to continue printing, but when this tray empties, it is ejected. If tray 1 is set to be the default tray, it is also ejected when empty. Can't find out why.
Set tray 2 to be default tray. When this is empty, the printer moves to tray 3, and then on to tray 1.
Posted on Nov 24, 2008
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Lexmark T632 has 2 (ea) 500 sheet drawers, but once the paper runs out in Drawer 1 it will not automatically pull from Drawer 2. Please advise how to fix this problem.
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Feb 15, 2011 | Lexmark T632 Laser Printer
Paper not pulling from tray 2 when tray 1 empties - Lexmark T654
For the majority of the Lexmark printers, all that needs to be done is to set the paper size and type the same for each drawer. Example - drawer 1 & 2 sizes are set to letter, drawer 1 & 2 paper types are set to plain. Set up this way, when drawer 1 empties, the printer will automatically switch to drawer 2 to supply the paper.
May 20, 2010 | Lexmark Office Equipment & Supplies
How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
1. On the home screen, touch Menu button
2. Touch Paper Menu
3. Touch Paper Size/Type.
Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
Feeder Type to appear as a menu item.
4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
6. Touch Submit.
Submitting changes appears.
7. Touch Home to return to the home screen.
Hope this helps.
Mar 16, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Dec 09, 2009 | HP LaserJet 4200 Printer
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Jul 02, 2008 | Lexmark T632 Laser Printer
Lexmark T632 Laser Printer Logo
578 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
