Question about Nikon D50 Digital Camera
Monitor on my D50 will not work
I am unable to use my monitor to check my pictures or get to the menu to change any setting pictures turn out ok but cannot use setting or view my pictures
  • irishbayou Apr 05, 2009
    I am unable to use my monitor to check my pictures or get to the menu to change any setting pictures turn out ok but cannot use setting or view my pictures, however the lcd will work to view the last shoy taken
  • 148 Answers
It sounds to me that their is a problem with the circuit board for the back of the camera. Please send it to a qualified repair centre.
Posted on Dec 11, 2008
The monitor has stopped functioning on my D50 The monitor has stopped functioning on my Nikon D50 digital SLR.Is there likely to be an obvious reason ie I've inadvertently pressed something that's switchd...
Even if you turned off the 'auto review', the monitor should come on when you hit the photo preview button. You can find out whether the monitor is broken if you hit the menu key - no image on the monitor, then it is burned out.
Aug 07, 2014 | Cameras
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
My monitor switched to a blue tinted display with low resolution and I am unable to change it in the properties menu?
Look to see if cables are ok in the back. You may have a faulty cable or faulty processing board in the monitor. Shut off monitor and computer. Turn on monitor first, then computer. Is screen still blueish? If so and cable are good your monitor is bad. It is very unlikely that it is your computer are when they fail they just stop working. Good Luck
Jun 28, 2011 | ViewSonic Computers & Internet
No picture on screen but power supply is OK
Here is a couple of suggestions for this monitor. 1st check your connection to the computer.
make sure the VGA/HDMI/DVI is properly connected. 2nd check to see if the monitor is setup
to use the right source. Some monitors do this automatically others may need to be manually set.
either look for a button to do this or bring up the monitors menu by hitting the menu button. If the monitors menu button does'nt bring up a menu when the computer is off then the monitor is probably bad.
If the monitor works until the OS boots then goes black. The video card in your computer is set up
improperly with the monitor . In Windows hit F8 as the OS boots this will cause the computer to boot in safe mode. Once in safe mode right click on the desktop then go under properties then settings and change the display option to the correct monitor. You can also go to the device manager in my computer under system information, hardware, device manager and change the monitor here also.
May 01, 2011 | BenQ FP731 17" LCD Monitor
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is...
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
Nikon d50 monitor does not work during photo shooting, must use view finder
This is completely normal. The monitor is used for setting menu items, displaying shooting info, and reviewing images. Like SLR have functioned for over fifty years, you take pictures by composing and framing through the viewfinder. Only the most recent dSLRs have the Live View capability which allows you to use the monitor like a point&shoot camera.
Apr 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Acer CRT moniter 17" Model: AC713 dost not display any thing.
Ok if you prese the menu button on the monitor does the monitors setting menu appear on screen
If it displays adjust the contrast and brightness until a picture appears
If that does not work place a fringe magnet on one of the corners of the monitor if there is now green tinge around it than there is no electrons being fired at the screen and you have missed something so test every component
Mar 14, 2009 | Acer AC713 17" CRT Monitor
Image not visible on monitor screen
you need to install camera drivers and application software again.
Oct 22, 2008 | Casio QV-R41 Digital Camera
For monitor display setting
Good evening Paresh this is viswanath Don't worry I can salove UR problem
First U go to Open Menu & go to Zoom option, select Zoom Function and press 30 sec
sercice manual is open Adjest UR settings & save it,turn of ur monitor.
Aug 16, 2008 | Computers & Internet
Monitor Menu Settings
there is in the menu that calls for " RECALL ", press this to go to original setting, and change setting again to your choice, individually.
Sep 25, 2007 | ViewSonic G810 21" SuperClear CRT Monitor
Nikon D50 Digital Camera Logo
135 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
