Question about NorStar Lands Phones
I have a norstar M7310, with 2 extensions on same telephone number. Whilst cleaning it i must have pressed a button by mistake and now my line 2 is barring all outgoing calls.It receives calls ok. How can I de-barr the line.
  • 911BJ Nov 21, 2008
    THATS NOT A SOLUTION. RE-SETTING TO COMPANY DEFAULT WILL LOSE ALL OTHER SETTINGS.
    I WOULD LIKE A SOLUTION TO THIS PROBLEM.
    THANK YOU
    Sergeant:
    Champion:
  • 347 Answers
You might want to review the manual:
http://www142.nortelnetworks.com/techdocs/NORSTAR_ICS_7_UG/pdf/m7310.pdf
Look on page 3.
Good luck,
Dahaka
Posted on Nov 21, 2008
    Sergeant:
  • 276 Answers
Reset your phone to the company defaults.
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
Jan 18, 2016 | NorStar M7324 Telephone
Norstar M7310 getting Not In Service message
This message means that the system does not see a telephone connected to that extension. Check the extension that you are calling to see if it is operational. Check the extension number by using Feature *0 and pressing the intercom button.
Apr 05, 2013 | NorStar Meridian M7310 Phone
Program personal speed dial numbers on a NorStar M7324 Telephone
For external numbers press FEATURE *1, then press the button you want to store the number on, then enter the phone number using the dialpad.
For internal numbers press FEATURE *2, then press the button you want to store the number on, then enter the extension number using the dialpad.
To determine what is currently programmed on a button, press FEATURE *0, then the button to identify and the display will show what feature or autodial number is programmed on the button. If the button is a line button or line pool button, you will not be able to clear it through user level button programming. System level programming must be accessed to change line appearances.
Mar 02, 2011 | NorStar M7324 Telephone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
WHEN I CAN AN EXTENSION A GET A MESSAGE THE THAT LINE IS NOT IN SERVICE. HOW CAN I FIX THIS?
The not in service message is given when there is no telephone attached to the intercom number your trying to call. I'd re-check the intercom number your calling, this can be done by using the button inquiry feature on the set your calling. At the set your calling, press feature *0, then press the intercom button on the lower right hand side of the set. The screen will display the intercom number of the set.
Sep 10, 2010 | NorStar M7324 Telephone
How do i program my nt8b20af-03 with an extension number?
If you plug the telephone into an activated (connected to the Norstar System) telephone jack, the lights should begin to blink while the phone boots-up. The system automatically assigns an extension number. To see what the ext. # assigned to the phone is, press "Feature * 0" (Button Inquiry) and press an intercom button. This will display the ext, # and Set Name of the phone.
Good Luck!
Aug 18, 2010 | NorStar Meridian M7310 Phone
How to use the to transfer phone calls
Call transfer on Norstar phones works by:
  1. Answer call
  2. Press the [Feature] [7] [0] (or simply press the [Transfer] button below phone display)
  3. Dial the number where you want to transfer the call
  4. Stay on line if wishing to speak to the person
  5. Press the [Rls] button to complete the transfer
  • If an external call is transferred to a busy internal or network extension, or is not answered after a few rings, the call automatically rings you back.
  • Note: Use Link to transfer callers to a telephone number
Oct 01, 2009 | NorStar Meridian M5009 Phone (NT4X35)
Finding the extension number
press feature *0. you can now look at any button on your phone to see what it is, touching the intercom button will tell you your extension
Aug 18, 2009 | NorStar M7208 Corded Phone
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
rings you back.
Sep 24, 2008 | Nortel T7316E 2-Line Corded Phone
Lands Phones Logo
41 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
