Question about Linksys Wireless-G WRT54GS Router (e125894)
Trying to turn a Linksys WRT54GS into a hub
I've been trying for some time now to switch my router which has been cauing my PS3 problems online, from NAT type 3 to 2 with little success. The most consistance method I've seen across the internet is to set up a DMZ with my router (a linksys WRT54GS), however this has not solved the issue.
Last night I came upon this forum post (http://boardsus.playstation.com/playstation/board/message?board.id=psnetwork&thread.id=32042&view=by_date_ascending&page=4) in which it was discovered that the problem arose because the modem provided by a person's ISP was also functioning as a router, and thus the solution was to turn the Linksys router into a hub/access point. When I folowed the instruction to plug the modem/router into a different port on the Linksys however, I was not successful, as when I attempted it I couldn't get access to the internet.
My modem/router provided by ISP TalkTalk is a SmartAX MT882. If there are any other details you need I can easily provide them, but if you would give me simple instructions on how to obtain them i would be very grateful.
WRT54GS WRT54GS)
  • 1 more comment
  • jonathanport Nov 22, 2008
    Sorry, when I do this I can no longer connect to the internet, perhaps if I give you more details we can be more successful? (I'd like to apologize in advance for my lack of technical knowledge)
    When I went to the IP address you specified (192.168.1.1) I was at the SmartAX MT882 settings. The tabs you described did not exist, they did however exist on the Linksys router's settings (which were found at IP adress 192.168.2.1). It is the SmartAX which is connected to the Internet, and the linksys (complete with 4 ethernet ports) which I wish to use only as a switch with wireless access point.
    Also I was confused by your step 4, does this mean there's no need for me to physically change the ethernet port it's plugged into?
    Sorry if this response is posted in the wrong place, I'm new to this service and was not sure exactly where it should be posted. Forgive me for holding off on rating you until we find a solution.
  • jonathanport Nov 23, 2008
    Yes the Linksys's IP adress is 192.168.2.1. The SmartAX device is plugged into the Ethernet port marked "Internet" on the Lynksys router, from the only Ehternet port on the SmartAX.
    I shall attempt your solution again.
  • jonathanport Nov 24, 2008
    Ah! Excellent, I've made the changes and everything is now working as it should. Just one more question, how do I access the Linksys device now if I wanted to change its settings? Its original IP address no longer works...
    Scholar:
  • 132 Answers
Oh okay. So your Linksys router has an IP address of 192.168.2.1? How is the SmartAX device connected to the Linksys router? Which port of the Linksys router did you connect the SmartAX device?
The steps 1-5 which I have mentioned should be applied to the Linksys router.
Hope this helps!
Posted on Nov 22, 2008
    Scholar:
  • 132 Answers
  1. If you want to set the router to work only as a switch with wireless access point, you may need to get into its setup page and adjust some settings.
  2. Using a computer that is wired directly to one of the router's Ethernet ports, launch IE and type 192.168.1.1. It is the default IP address of the router. Then it will open a window, asking for a username and password. By default, there is no username and the password is admin.
  3. Once you're in the router's User Interface, look for a sub tab called "Advanced Routing" under the main tab SETUP. Then set router mode to "Router" instead of Gateway. In some router's, the choice there is NAT enable or disable. If it is the one showing there instead of Router mode, then set NAT to disable. Click Save settings which is located at the bottom portion of the screen.
  4. Then click on "Basic Setup" and then disable DHCP server. Save the settings then.
  5. Then your modem now will be connected to one of the 4 Ethernet ports of the router.
Hope this helps!
Posted on Nov 21, 2008
  • Jannette Amandy Nov 23, 2008
    If the Linksys router will be set to work only as a switch with wireless access point, then the SmartAX device shoould be connected to one of the Ethernet ports of the Linksys router. So, after doing the steps I have given you, connect your SmartAX router to one of the Ethernet ports of the Linksys router.
    Please update me about this.
  • Jannette Amandy Nov 24, 2008
    Should you wish to access the Linksys router's setup page, then you may need to assign a Static IP address to the computer you will use. This is because, all your computers are getting their IP address from the SmartAX router. So, if you want to access the Linksys router's setup page, an IP address that is on the same segment as your Linksys router will be assigned "for the meantime" to the computer you will use.
    To assign a Static IP address to the PC:
    1. Go to Control Panel>Network connections.
    2. Right click on Local Area Connections and then click Properties.
    3. Look for Internet Protocol TCP/IP. Select it then click Properties.
    4. By default, TCP/IP is set to dynamic IP or Obtain IP Address Automatically. Select Use the Following IP address.
    5. Set the IP address to 192.168.2.2 and Subnet mask is 255.255.255.0
    6. You may leave Default Gateway and DNS servers blank.
    7. Just click OK all the way out and you should be able to access Linksys Router's Setup page.
    8. When you're finish doing the changes you want to do in your Linksys router, go back to Control Panel>Network Connections>Local Area Connection>Properties.
    9. Select TCP/IP then properties and set IP address and DNS servers to Obtain.
    Hope this helps!
Problem accessing www.192.168.1.1... I have a linksys Wireless Router WRT54GS v5.1 . I am trying to access the setup area of www.192.168.1.1 and reset my wireless router whichhas stopped working ....
the usual address for that model is http://192.168.1.1
So what you tried without hte www.
Tell me if you can access it again with that.
Regards,
Jan 10, 2011 | Linksys Wireless-G WRT54GS Router...
Hello i am trying to connect to me friend on xbox live with a WRT54GS linksys router and i unchecked the nat filter and the upnp is enabled but i still cant connect
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
May 20, 2010 | Linksys Wireless-G WRT54G Router...
Trying to set up wireless router on PS3 and I need to hold in the AOSS button. Where is that button?
LinkSys does not have an AOSS button. It has a CISCO button. It is on the outer edige of the router. Press and hold until it starts flashing white.
May 01, 2010 | Linksys Wireless-G WRT54GS Router...
I trying to fix a small office network and need some help. I have a netgear ds116 hub that currently has a linksys WAP54G access point connected to it for wireless access. The access point is not encypted...
So have a hub and a wireless access point at office.
Do u have a router in the network at office ?
The default IP address of the WAP54G will be 192.168.1.245.
The Sonic firewall is a different thing.
I think you are accessing the set up interface of the sonic wall with the IP address 192.168.1.1.
Where is the access point connected ?
Is it connected to the sonic firewall ?
The access point does not have the DHCP server.
Click Here for more info about Access point
Oct 07, 2009 | Linksys Wireless-G WRT54GS Router...
I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
Oct 06, 2009 | Linksys Wireless-G WRT54GS Router...
WRT54GS possibly to slow during movie downloads/PS3 online gaming
dd-wrt.com i hate original firmwares. this is linux based ,have documents, and good forum. try to change firmware on you router.
May 30, 2009 | Linksys Wireless-G WRT54GS Router...
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Linksys nh1005 ver. 2.1
first make sure that you are getting lights on all of the devices at the hub, and also that all four are getting ip addresses. if the 4th device is not getting an ip address but does show connected to the hub, then the problem is more than likely your router is not serving enough ip's for all of your devices. also make sure that everyone of the devices are not assigning a static ip that could possibly knock out one of your devices, or if they are all static ips, that one of them is not set to the same ip as another.
Jun 21, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Linksys WRT54GS not detected
I am having the same problem with the WRT54XG4 but i discovered that if you disconect the internet port of your router and leave the ethernet port conected to your computer. You can access to the router and you can upgraded.
Hope it help you
bye
Feb 24, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs cant connect..
hi try this before you hit the reset botton. Check if Windows XP firewall or 3rd party firewall are blocking the pings, and temporarily disable them just to be sure. The WRT54GS has a feature called "AP Isolation", It's on the "Wireless -> Advanced Settings" page. You won't need it for home use so turn it off as well. Last thing, do a firmware upgrade. Hope it's helps Good luck.
Mar 20, 2006 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
1,275 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
