Question about Kenmore 25862 Top Load Washer
Kenmore washing maching 25862
Washing machine fills with water but will not agitate or spin and makes a loud clanking/rachety noise when the motor runs. It is direct drive. I am guessing that something has broken in between the electric motor and the drive.
  • 1 more comment
  • mike_07006 Jun 25, 2008
    Re: 25862
    washing machine wont spin when on spin cycle. The machine sounds like it has empty reaching. how do i get the water out of tub and hose line and what part is broken /
    thank you
  • Anonymous Mar 16, 2014
    how to use the washing machine ddmotor direct drive motor
  • 60 Answers
Yes you need to replace the motor coupling between the motor and transmission let me know how you make out
Posted on Sep 14, 2007
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Washer does not agitate or spin. makes loud noise when it's on:filling, trying to agitate or spin and emptying.
Possible that the INLET valve is also making noise due to faulty coil, check , confirm by disconnecting the valve.
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 24, 2013 | Washing Machines
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
Jun 28, 2012 | Kenmore Washing Machines
My Kenmore 80 Series washer won't agitate or spin. Makes noise.
sounds very much like the bushes have worn out on the motor,they are easy to replace take down model number to your nearest electrical shop and they will supply them for about £10.00
Jun 07, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not fill or spin, makes a loud noise
The timer is likely failed if both these are happening simultaneously.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Kenmore 25862 Top Load Washer Logo
94 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
