Question about Microwave Ovens
SHARP MICROWAVE WON'T WORK
Somehow my parents (elderly) went to use Sharp microwave and when they punch in the time and try to hit start the word lock shows up on it and it won't work can you help me out, is it junk or something simple?
  • Microwave Ovens Master
  • 9,098 Answers
Sounds like the child lock has been activated.
Press the Custom Help or Help button to find & change the child lock settings.
Otherwise, please reply back with your model number so we can help you better.
Posted on Nov 23, 2008
Microwave is locked up. Says Lock on screen and cannot get it to go away after hitting Clear several times. How do I get it off "lock" status?
HELLO.
GE manufactures various models of microwaves with a range of features.
Among them is a child safety feature that allows parents to lock the keypad. Though children can still open the door, the keypad lock prevents them from starting the microwave. The lock is in the form of a keypad code that renders the buttons inactive.
* 1 Press and hold the "Clear/Off" button on the microwave's keypad.
* 2 Hold the button down for three seconds.
* 3 Wait for the "L" on the keypad's display to disappear and display the time instead, signifying that the device is no longer locked.
Willing to help solve more problem.
Thanks.
Aug 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Was working fine, punched in time to cook, hit start ...it ran for a second and then just went dead. No light, no display Microwave is 10 years old but never had a problem before
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 11, 2011 | Whirlpool MH7140XF Microwave Oven
Somehow I have "locked my microwave - when I try
Easiest thing to do is to unplug it or turn off power at breaker for a couple of minutes, should reset.
Nov 14, 2010 | Sharp Microwave Ovens
Locked timer/keypad
Try unplugging it for a few minutes. If that fails, read the owners manual for instructions on how to unlock.
Jun 26, 2010 | Maytag Appliances Over-the-Range Microwave...
Clarification on microwave
That would be a bad primary interlock switch (bottom door switch) or its mount is loose or broken.
See this link: http://www.microwavedisplay.com/doorsw.txt
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 02, 2008 | Microwave Ovens
Microwave lights up, timer works, not carousel or cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Otherwise, the best place to order Sharp parts is Tritronics.
You can also call them at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Sharp Microwave R-520L stopped working
My parents had the same problem. It turned out that a switch went bad. When you take the case off, there are 3 switches where the door latches. The bottom switch went bad. It is an Omron D3V-16G-3C25 switch.
Nov 13, 2008 | Maytag MMC5000 Microwave Oven
Lost power suddenly
Could be; replacement fuses avail @ RadioShack or a similar place for a few bucks, so it's worth trying. Just remove the outer casing, look for the white plastic snap-on container (might say "FUSE" on the side). See this also:
http://www.partselect.com/microwave+replace-fuse+repair.htm
Jan 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
