Question about Hotpoint Washing Machines
Smells coming from machine, leaving washed item's smelly
  • 367 Answers
Get whirlpools new affresh washer tablets. They clean the inside off the machine and kills mold ect. and if used regularly it keeps your washer smelling fresh. They are designed for front load machines but work great in top loaders too. They are available on line at any parts store and are around 8 bucks.
Posted on Nov 21, 2008
Why is my washing machine so smelly i have done 90 degree wash with no clothes but smell still comes back
When the clean light comes on use an afresh tablet and always leave the door open when not in use.
Apr 03, 2015 | Washing Machines
Washing machine is smelly
If you read the info with the washer, it tells you to leave washer door when not in use , there is as los a freshener tablet to use when the clean light comes on. This will keep your washer smelling fresh.
How do we deodorize a smelly front load washer?
Buy the washing machine cleaning products near the laundry soaps. I believe Tide sells one.
Aug 09, 2014 | Frigidaire Washing Machines
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
My washing machine leaves the clothes smelling bad and i call lg support and they don't want to fix the washer and the lg man came out and said thats a manufacture proble and gave me a case number and...
To prevent a smelly washing machine, leave the lid open on the washing machine when a load is removed to allow it time to dry out. If smells do happen, try washing an empty load with hot water and a mixture of baking soda and vinegar. For front loading washing machines, it is vital that you leave the washing machine door open in between loads. You will also need to wipe down the rubber seal of the washing machine. Small bits of debris and hair can become trapped in the crevices. Giving your machine a quick wipe down after each use will prevent smells and mildew. ONCE YOU GET IT CLEANED OUT IT SHOULD BE GOOD AS LONG AS YOU FOLLOW THESE STEPS.
There are also videos on Yu tube under how to clean a washing machine.
Aug 15, 2011 | LG Washing Machines
Smelly washing machine
put some bleach in the washer and run a rince wash (nothing in the washer) then run 3 more rince washes to clear out all traces of bleach before you put any closes in it,(or do a hot white wash only) this should work ok, when not in use all ways leave the door open if you can to change the air inside your washer it stops them smelling
Jun 08, 2010 | Samsung WF337AA Front Load Washer
Fowl Smell
If the smell is a mildew type odor this is common with the newer energy efficient machines. To remove the odor I would suggest using a product called Affresh or Smelly washer. These used on a monthly basis will help eliminate and keep it from coming back. If it is practical to leave the lid open when not in use that will also help. The products I talked about are available at Target, Lowes and grocery stores near the laundry detergent.
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Smelly washer!!!!!!
Check the drain hose for gunk then:
Fill up the tub half way with water (small load) put a cup of vinegar a 1/4 cup of baking soda let it foam up then run the washer through a regular cycle empty. If this does not work: you will need to use a commercial mold removing product.
Mar 17, 2010 | Washing Machines
My washing machine is smelly!! I was told that I
You don't neeed to remove anything Just set it to large load hot water and add 2 cups of bleach. Run it through 2 cycles. If the smell is still not gone completely repeat.
Never had this fail.
Hope this helps
Please leave feedback
Nov 29, 2009 | Cars & Trucks
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
