Question about Lasko 5540 Ceramic Compact Heater
Absolutely no power to my Lasko 5540 heater
When I plugged in the heater I noticed that there was no power at all. I tried several outlets in the house and still nothing. I can not find any indication of it shorting out/burning out. Thanks
  • mulberrylady Jan 27, 2009
    Same problem, however I had the fused checked by an electrician and it tested ok. So that did not resolve my problem.
    Champion:
  • 242 Answers
There is a thermal fuse in line with the power chord. Open your heater housing up and trace the power cord. It is located inside a white teflon sleeve. Locate the fuse and either replace it with the same value. Appliance repair shops will have them in stock. If you want heat right away, cut out the fuse and jumper the 2 wires together. Instant heat.
Posted on Nov 21, 2008
Hi, I have the Lasko Ceramic Elements heaters. When I plug it in, the light lights up to show it's plugged in, but when I try to press the POWER button turn it on, it beeps but does not do start heating...
If I am getting this right you just purchased this heater? I would return it and get another one. It sounds like the tip over switch is not made and will only show that power is getting to it but the tip switch is keeping it from heating.
Dec 14, 2010 | Lasko 5540 Ceramic Compact Heater
Why does the cord get hot
if your cord is getting hot you should have it replaced with a heavier one or throw out your .heater. hot cords are a serious fire hazzard. if the heater is fairly new take it back where you bought it
Dec 09, 2010 | Lasko 5540 Ceramic Compact Heater
How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Feb 08, 2009 | Lasko 5540 Ceramic Compact Heater
Honeywell
You have too many things on the circuit you are on. Either move it to a different plug, or turn some things off. A plug in heater uses as much electricity as the breaker should carry if it is a 15 amp, like most are. Try to find a plug on a different circuit, or clear some things off of it.
Dec 22, 2008 | Lasko 5540 Ceramic Compact Heater
How to clean filter on Lasko tower ceramic heater
Thanks for the response = I blew the filter clean with a forced air canister.
Nov 29, 2008 | Lasko 5540 Ceramic Compact Heater
Iflo digistat+2RF remote control for combi boiler
there should be an overide button on reciever try checking if stat is still communicating with reciever when stat is turned up and down light should flash on reciever
Oct 23, 2008 | Lasko 5540 Ceramic Compact Heater
No power
Go to the Lasko Website and get a new one for free. They were recalled
Jan 17, 2008 | Lasko 5540 Ceramic Compact Heater
Popping, smoking electric Lasko 5540 heater
Connector for power cord overheats and shorts. Bottom safety screw can be undone using the bacj end of a jig saw blade.
Replace wire connectors with different wire connectors - wire nuts etc.
Nov 05, 2007 | Lasko 5540 Ceramic Compact Heater
Poping, smoking electric Lasko 5540 heater
It depends on where the smoke is coming from. If it's from the heating elements, it's normal as dust and residue burn off. If it is coming from the control section, it's bad and the heater should not be used.
Lasko 5540 Ceramic Compact Heater Logo
508 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
