Question about Vivitar ViviCam 3755 Digital Camera
Power buton problem
When used after a weak or more power button (On/Off) button does not respond. Problem persisted even tried fresh batteries, also used contacts cleaner like WD40 that doesnot solve itpermanantly
  • 88 Answers
1.remove memory card and try it to switch on the power.
if ok
then insert the memory card and try factory reset option.
2.and copy all the datas from memory card to computer or anything.
3.fromate memory card . and switch off and switch it on. wishnyou all the best.
Posted on Nov 21, 2008
The battery in the heli dies within minutes of use even after fully charged
Sounds like you need a new and fresh battery.
try www.batterybuyer.com I use them a lot.
Dec 28, 2015 | Toys
On my Tanita BC-534, I just changed the batteries but now continually get "Lo" in the display. So tested batteries and even tried other batteries, but still get the same message. Please let me...
Hi BJ,
Welcome to fixya!
According to the manual, "Lo" indicates weak batteries. Since you changed batteries, my next question would be... Did you buy fresh batteries at the store or use ones you had at the house? Check the freshness date on the battery package. Sometimes even some of the ones you get in stores aren't fresh enough.
Since you get enough power to get "Lo" reading, but not enough for anything else, this sounds like a battery problem.
Did you check the contacts in the battery compartment? Sometimes cleaning them with a pencil eraser will help make better contact. Also, be sure the springs are tight enough. If they are the tab kind, you can bend them out a little for a tighter fit.
If all else fails, here is the contact page for Tanita: http://www.tanita.com/en/contact-customer-service/
They should stand behind their products.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 26, 2011 | Tanita BC-534 InnerScan Body Comp Scale
I get no power when using fresh AA batteries or charged (Ni-MH batteries). Camera works fine when using AC power adapter.
Please make sure that you're using the LR6 AA sized batteries and also the terminals of the batteries are correctly inserted. Also make sure that the terminals of the battery compartment is clean without any obstacles or dirt. Also, try power reset and check if it helps.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If the issue persists, try the factory resetting. SETUP MENU-->RESET ALL--> OK
This should resolve the issue.
Thanks for using FixYa.
Jun 06, 2011 | Fuji FinePix 3800 Digital Camera
What could be the problem if the ignition does not respond
Hi and welcome to FixYa!
As a first course of action I strongly suggest that you remove the positive battery connector, let it sit for atleast 5mins. then reconnect it again. This will reset the system and can get it back to it's normal operation.
If the problem still persists, please try to use a different battery for it may be weak. If the fully charged battery still doesn't respond then the problem will be on the starter itself. If the starter is faulty it won't kick the flywheel which may cause the vehicle not to start.
Hope this helps and thank you for using FixYa! Have a good one!
Feb 15, 2011 | 2003 Honda Pilot
My sb will power on but i have no flash even when i hit the test button. I noticed it got a little warm then shut down when the problem first occured. Is it fried or fixable?
Are you using fresh batteries? Are they rechargeable batteries if so do a battery test maybe a battery is weak. With fresh batteries it still does the same thing then call Nikon 1-800-645-6689
Aug 28, 2010 | Nikon Speedlight SB-800 TTL Flash
ON\OFF buton is not responding. The phone is
The power (On/Off) button is not responding probably because it is broken, the phone is dead, or the battery is dead or drained. Connect the phone to a charger and check whether the phone charges the battery or not. The power button is indeed not responding and broken when the phone charges the battery. The only way to turn on the phone is by replacing the power switch.
When the phone doesn't charge the battery, the phone may be dead or the battery is dead/drained. To revive the battery and verify whether the phone is dead or not, check it here.
Apr 06, 2010 | Nokia 6233 Cellular Phone
Won't work after replacing batteries
sounds like the batteries might be in backwards. Please remove the batteries and then put them back in insuring that they go in correctly.
Oct 30, 2009 | Computers & Internet
Why isn't my Kodak CX6330 responding?
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Oct 02, 2009 | Kodak EasyShare CX6330 Digital Camera
Pentax K100D will not power up
First make sure you are using fresh lithium batteries. These cameras indicate low batteries quite early on. Rechargeables even when freshly charged are marginal.
If the problem persists remove the batteries. Set the camera switch to the off position. Set the focus switch to manual. Wait at least a minute. Then replace the batteries and switch on again.
Operating with low batteries can confuse the firmware and it may be stuck in a low-battery loop. If this is the case this should reset the camera by allowing the electronics to power-down completely.
If this does not work you wiil have to contact pentax support.
Dec 31, 2008 | Pentax K100D Digital Camera
Samsung BD-P1200 (Bluray) Remote Control stop responding
Try resetting it.
Remove the batteries and hold down the POWER button on it for 30 secs. Then replace the batteries with fresh ones.
Dec 19, 2008 | Samsung (1012861) Remote Control
Vivitar ViviCam 3755 Digital Camera Logo
65 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
