Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Color guns out of alignment
Have a 53" Panasonic HDTV 1080i projection set. Model number is PT-53WX53-G. Unit manufactured in 2003. Colors are out of alignment. No luck resetting to default settings. I have tried to adjust color guns using my remote (as per the owner's manual). I have been able to realign the blue color to the target, but cannot get the red color aligned. I can move the red color "alignment cross" up and down, but have only limited movement laterally. The red "alignment cross" is left of center at all stations. I can get the red "alignment cross" to move further left, but cannot get it to move back to the right. Any obvious maintenance a layperson can try inside the console? Willing to get inside and tinker, but am by no means a qualified electronics tech. I do have a service call scheduled, but wanted to see if there might be solutions I could try in the interim. Thanks, Tim
  • 1 more comment
  • doc1newell Nov 15, 2008
    My red and Blue align using the remote , but green is way out
  • AUTUMN060707 Feb 24, 2009
    pt-61hx40b chassis #bp819 2 years ago this month i had my 2 convergences ic's 392110 replaced but the blue is still out,in 1080 i when used w/xbox 360 it is really out.did the eprom need to to be adjusted? when convergence ics put in person/friend had no service manual to let them know possible eprom reset unlike magic focus w/ hitachi brands.4-5 months later person thought that eprom needed to be adjusted after working on a few more 61 s and some 51 s from panasonics.when using cable its only slightly noticeable.when in hi-def really bad compared to standard.
  • Anonymous Mar 29, 2014
    am adding a R.C.A digital antennae to try & pickup some stations & can't select "signal meter" as per t.v. instructions. it has a gray color which i can only assume that this model won't allow, though it doesn't state that anywhere in owner manual.
  • 934 Answers
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Posted on Dec 07, 2007
I have a panasonic 1080i projection tv.i cannot align my color i went to convergence to align and thay will not align
Posted on Oct 14, 2008
I Have a Panasonic HDTV 1080i. I tried to turn it on today but the power button just blinks yellow. What does that mean?
The blinking power indicator is actually identifying the ircuit which is stopping the set from working. How many times is the light blinking? Please respond to this sme post for assistance.
Sep 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
What is the make and model# for a replacement lamp on this Panasonic PT-53WX53 53 in. Rear Projection HDTV
MODEL NUMBER INDICATED DOES NOT USE A LAMP! IT HAS THREE PICTURE TUBES; IF CORRECT MODEL NUMBER WHAT IS WRONG WITH THE SET====WHAT IS IT DOING OR NOT DOING?
IF THIS INFORMATION WAS HELPFUL RATE this solution as very helpful as I do this here for free.
Comment here if you have questions or need help--I am here to help.
SD TECH
Aug 21, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Colors are not aligned
Can't use the flash focus button or the convergence control crosses +s don't alignes red,blue,green colors.The tv have convergence problems,it dead.Must replaced 2 STK convergence ICS,and some or all it resistors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | Panasonic PT-53WX53 53" Rear Projection...
My screen has a blue rainbow across it that pulls picture upwards projection tv 1080i
Replace Both of your STKs convergence ICs they are big black ICs.will have part numbers on them.
Jun 09, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence Problems with red to left of screen.
Replace Both STKs convergence ICs number of part will be on them STK392-110 if this is the number use 180s To order Parts Go To www.electronix.com or Call 1-900-223-3205 These ICs are big black chips.
Dec 14, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53G 53' projection tv problem
was your tv hit hard,a non magnetically shielded speaker set on top or under it?
Nov 09, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Green....purple....colors
If you are technically savvy and you can solder.....requires
chassis pull...replacement of convergence IC's...mounted on large heatsinks on board to the right looking in from rear....If
you want help........Let me know................T.
Dec 27, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Blue color gun off line
Milt,
What are you referring too when you ay the blue color gun is offline? Is the blue crt not lighting? Or just the convergence alignment off??
Bill
Nov 23, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
1,974 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
