Question about Philips DVP3345V/17 DVD Player/VCR
DVV Player won't play disc
I have played this particular disc a hundred times before and now all of a sudden it won't read and I get an error message, saying, "disc error: this disc may not have playback features".
    Champion:
  • 242 Answers
Check to make sure your player can play other disks. If so then use the disk doctor to remove the scratches on your favorite disk. The area that all DVD players scan before playing a disk is probably smudged or scratched.
Posted on Nov 21, 2008
My dvd player won't play dvd
likely if cannot read disc, or no disc or error, that unit has either dirty or bad optical pickup.
May 14, 2012 | Televison & Video
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
We bought the Burlesque dvd and our blu-ray player cannot read the disc? The error messages 'cannot operate this disc and cannot play back this disc. This is the first dvd the blu-ray player cannot...
It's something about the Burlesque dvd. I have the same problem with mine when I try and play it on my Sony blue-ray player. It's the only disc I have that it won't play. Disc is a DVD Video disc but it will no't play in the Sony player. It plays fine on other dvd players and my computer, but not on the Sony.
Jul 16, 2011 | Sony Televison & Video
I am trying to play a dvd in my 2007 Tahoe. It will not play and gives me an optical error message. Any thoughts?
{: ) If you have been playing DVD normally before on your Tahoe, and now you read error messages, it could be the player or the disc at fault. Most of the time it is the disc at fault. As much as possible, the discs shoul be clean and scratch free, not warped, and compatible to your player. Avoid using discs with paper label. Try a known good DVD disc and observe for any progress.
Just in case it's the first time you try and you have a navigation radio, check again your RPO lists. and look for a UVB listed on the RPO sticker. Or simply check the DVD symbol on the left lower corner of the radio, which indicates that it is capable of playing DVD audio or video.
Jun 27, 2011 | 2007 Chevrolet Tahoe
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
My Panasonic TV has a built in DVD player. Won't read the disc- get message
Check and replace the laser pickup unit. It is faulty [Weak]. If you wish to get some details; visit the site linked here. Pull up older posts.
Dec 28, 2017 | Panasonic PV-DF2703 Triple Play 27 in....
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
Philips DVP3345V/17 DVD Player/VCR Logo
371 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
