Question about Jenn-Air JFC2089HE French Door Refrigerator
Right side french door does not stay closed
If the right door is closed and you then close the left door, the right one opens.
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Posted on Jun 18, 2009
4 Suggested Answers
  • 28 Answers
SOURCE: Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Posted on May 09, 2009
SOURCE: right door will not stay closed
Put vaseline on door seals
Posted on May 26, 2009
  • 11800 Answers
SOURCE: after 6 years the right
Either the door gasket has worn out and it should be replaced with a new one
http://www.easyapplianceparts.com/MultiModels.aspx?ModelNum=jfc2089he&searchTerm=img_56471&RefineSearch=0&imgMfg=Maytag
or there is something that is pushing on the door frame or the shelves that is preventing the door from closing. If you are sure that nothing inside the fridge is badly seated then the problem must be on the inside of the door frame - humidity has got in and has made the insulation swell and buckle the internal panel. To fix that the entire fridge will have to be dismantled, the insulation dried and packed back in its place - a job for a pro, you will have to call one.
Posted on Jul 08, 2011
The door flap on my KitchenAid French Door fridge isn't springing completely back into place, and it's catching on the other door.
Locate and adjust the spring responsible for getting that flap into proper place and all will be resolved.
Aug 30, 2015 | KitchenAid Refrigerators
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
Right door flap not hugging door when ioening left door with right door already open
The doors have to be adjusted. They may have moved out of their intended alignment over time
May 01, 2013 | Frigidaire FGHG2344MF Bottom Freezer...
Doors not closing all the way
check level from back to front on fridge if good than check the amount of food that is stored on the door if u have a lot of bulk, weighty stuff they may be acting as a counter balance on the door when u close the left side the air that is trapped usually disperses into the unit and is not forceful enough to push open the door but if their is a lot of additional weight on door it makes the door easier to open and swing on hinge
Apr 21, 2010 | Jenn-Air JFC2089HE French Door...
Right door opens when I close left door
This happens because the two sides are ducted together and when you close one hard enough the air is one chamber is pushed int the other and it forces the door open, All you can do is be sure the gaskets are clean and seating firmly on the frame and adjust the front slightly higher so the doors re-close.
Eric
Sep 15, 2009 | KitchenAid Architect KBFA25ERSS Stainless...
Right side door pops open when left door is closed
Is this a new unit? This is caused by air rushing into the other compartment through a damper control. Most mfr's. install an air check valve at the bottom of both doors that will pop up to let external in, thus alleviating door blow out.
Apply a food grade silicone to the face of the door seals to add tackiness to to the surface. Follow link to purchase.
https://www.repairclinic.com/PartDetail/Silicone-Lubricant/WP99003172/1074750. A suitable substitute would be a little Vaseline.
Oct 11, 2017 | KitchenAid Architect KBFA25ERSS Stainless...
Right door will not stay closed
May 26, 2009 | Maytag MSD2758GEW
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
Jenn-Air JFC2089HE French Door Refrigerator Logo
640 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
