Question about Nintendo Wii Console
Wii console keeps swiching on after i set it up wirelessly
After setting up wirelessly my console keeps switching on automatically
  • opti459 Nov 21, 2008
    Not auto turn on because it still in power-off mode, blue lite come from the slot opening, it could be some activities such as up-date the system from internet?
    I have two Wii at home, both has the same issue. I just unplug the power & re-connect wii if I want play.
Whenever the wii is getting information online, the disc slot blinks. it is supposed to do this (ps do not confuse the green power light with the yellow)
Posted on Nov 26, 2008
Connecting to enternet
Make sure you have created a NEW internet connection in your Wii System settings. Since you have changed your service, your old connection settings will no longer work. Go to your system settings from your main Wii menu, and select internet connection to set up a new one.
If you have already tried to set up a new connection and still cannot connect to the internet, make sure your router security settings allow your Wii to connect to your wireless internet.
Oct 24, 2011 | Nintendo Wii Console
I have a wi console where stream net flix I can not get it to conect I keep getting error code 52130. How do I fix it.
To solve this error, try to manually setup the Wii console using your network IP settings.
To do a manual setup of the Wii console using your network IP settings :
  • On a PC, click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter.
  • Locate IP settings and use them to manually set the Wii console.
  • Restart your wireless router by unpluging the power from the wall and plugging it back in. Try to connect the Wii console to the internet.
You may also try to disable the wireless router security or firewall. Try again to connect the Wii console to the internet.
if this help you please rate me tnx...
Jul 28, 2011 | Nintendo Wii Console
If i have wireless internect, how do i link my wii with it?
Wireless Connection
1. On the Wii console's main menu, click on the 'Wii button' in the lower left corner.
2. This will take you to the settings screen. On this screen, click on 'Wii Settings'.
3. In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
4. Select 'Connection Settings'.
5. Select an open connection, indicated by 'None'.
6. Select 'Wireless Connection'.
7. Select 'Search for an Access Point'.
8. At this point, the Wii console will search for any identifiable Access Points nearby. Once this search has completed, you will be directed to choose the Access Point that you wish to connect to. Click 'OK' to display the list of available Access Points.
9. Select your Access Point from the list of available Access Points.
If your connection appears as a closed padlock, then the Access Point requires a security code or passphrase. The security code or passphrase can usually be found on the security tab of your wireless router settings.
If your connection signal appears yellow or red, the stability or strength of the connection is not optimal. If possible, remove any obstacles between the Wii console and the Access Point. I've also found that changing the channel on your router to channel 1 or channel 11 can sometimes help with singal stability and strength.
10. Click 'Save' followed by 'OK' to save your connection settings...
11. ...and select OK again to start an automatic connection test.
If the test succeeds, Internet Setup is complete and your Wii conosle is wirelessly connected!
Jul 13, 2011 | Nintendo Wii Console
Cannot connect to internet with my wii
If you are connecting the Wii wired to router, check If the IP address is set to static. If it is, set it to automatic
if you are connecting wirelessly, please follow this steps:
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Now, select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection 1: None"
5.Click on "Wireless Connection" and then "Search for an Access Point."
6.Select "OK" and the Wii will display all the wireless networks it finds.
7.Select the wireless network that is yours.
8.Select "OK," "Save Settings," and then "Yes."
Jul 12, 2011 | Computers & Internet
The wii shopping channel wont open so i can download netflix
You may need to update your wii console in order for you to get to the wii shop. Try a system update from the system menu and then try again with the wii shop. I hope this helps!
Apr 27, 2011 | Nintendo Wii Console
Trying to connect to wireless internet
From the main channel menu on the Wii, hit the Wii button. Then navigate to Wii Settings > Internet (page 2). Select an empty connection, choose your connection type and then follow the on-screen instructions. You should first try choosing "Automatic" or "Auto-Detect" whenever possible. If that doesn't work, try using Manual settings.
Here's a detailed guide on how to set up an internet connection.
Hope this helps!
Mar 25, 2011 | Nintendo Wii Console
Need to know how to hook up the internet through the wii with the wireless device
Select the "Wii" button in the lower left corner of the main screen, then go to "Wii Settings." Find the "Internet" button, and click it, then click "Connection Settings." Select a connection, choose "wireless connection," and then hit "Search for an Access Point."
Wait for it to do it's thing, then click "Select Access Point." Select your wireless network and enter the neccassary Key/password if applicable, then click "Ok" to save the settings.
The Wii will then test your connection, and if all is well you will be required to update your system by downloading the newest software for it, which will happen automatically.
Mar 10, 2011 | Nintendo Wii Console
Can't connect to internet to download netflix
Check if your wireless router is set up to DHCP (this means that it gives out ip adresses automaticly) If its nbot set to that, or it cant be set to DHCP, Try setting the Wii to manual ip, choose something like or As these are often used ip lines.
Mar 08, 2011 | Nintendo Wii Console
Wii internet connection
go to the wii settings then set connection as connection 2 then set it for wireless access then search for your router then input wpa-psk or wep key then i should start to connect then it should upgrade then connection complete then go back to wii main menu
Jan 27, 2010 | Nintendo Wii Console
Setting up wii wireless
log on to the router and get the right wireless key if the router has multiple solts to enter wifi key select to 1 if the above is right its its to do with mac filterting if the mac filtering is enable u must add wii mac address to allowed list if the mac filter is disabled no probs try changing the channel set to 11  set the wireless to mixed or b/g mode try manul set up of wii try turning off the router and wii  then confuguring again hope this will fixya
Nov 02, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
