Question about George Foreman GR35TMRCB Indoor Grill
Top grilling surface
The top grilling surface does not appear to be working on my grill (- it did not get hot during its last use). I thought that it was suppose to get hot. Is there anything that I can do to repair this problem or should I just throw it out and buy another one?
  • bimma Nov 27, 2007
    my grill does not heat up. should I trhow it away?
If you can access the electrical connections, ths should be an easy fix. If this has a temp setting or switch, it could be a loose connection at that control, or a loose connection at the heating element. for some reason, you're not getting power to the element.
Posted on Jan 04, 2007
Need to re paint my grille
automotive paints require a good clean and well prepared surface like light waterpaper sanding to remove any oily or fatty resedu and the correct undercoat before applying a new coatings otherwise it will not last chipping or peeling will occur.
May 06, 2013 | Cars & Trucks
I have a Char-Broil Tec grill everything works fine but after about 2 minutes into grilling, a loud popping sound and the tec-radiant burner goes out, this happens everytime I use the radiant burners
The radient burner most likely has a crack in the top. This will make the pop and the burner will go out. Inspect the top of the burner for any cracks, if you find one, the only solution is to replace the burner. Since these burners get very hot, I do not recommend having the grill lid closed when these burners are being used, this can cause them to overheat and crack the top surface.
Jul 03, 2011 | Tec RadiantWave Grill
I have my Weber Q grill hooked up to a large propane tank rather than the small tube type. It worked fine for a few weeks but now the grill only gets medium hot. Not hot enough to cook anything really. ...
Seems as if your grill is suffering from "Clogged Burner Syndrome". But, don't despair, it's easily solved by removing and thoroughly cleaning the burners or "coil" as you called it. Also, pay particular attention to the venturi valves on the open end of the burner. Spiders like to build nests in them. The venturi valve will look like a slot on the right and left of the burner tube, where it fits over the burner orifice. It's really a good idea to perform this routine maintenance, at the start of each grilling season.
When it comes to gas grills, it's like Benjamin Franklin said, "Cleanliness is next to Godliness."
Hope this helped you solve the problem. Happy Grilling!!
Jun 02, 2011 | Weber Q Grill
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
PUT WEBER PROTECTIVE COVER ON WHEN GRILL COVER WAS STILL HOT
Use a mild non-abrasive cleaner first. I that fails try automotive compound (which is slightly abrasive but won't scratch the metal surface if used as directed.
May 25, 2010 | Weber Genesis Gold B Grill
Need sq inches of grill model no ggr50b
This grill is supposed to have 200 square inches of cooking surface. I hope this answers your question. If you need or want to know anything else I can help you.
Nov 23, 2009 | George Foreman GGR50B Grill
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Ovens
Can nonstick surface be replaced, how and what
I wouldn't suggest spray on Teflon - even if it can withstand high temperatures, in prolonged use the Teflon Spray you can buy isn't really supposed to be used for food prep. If the grill still works okay then keep the grill; prices of George Foreman grills have fallen due to Russell Hobbs who have brought out larger grills for the same cost.
May 06, 2009 | George Foreman GR30 Indoor Grill
Gas leaking on grill
The valve needs to be opened up and cleaned.
Aug 01, 2017 | Thane Q-BBQ Grill
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
George Foreman GR35TMRCB Indoor Grill Logo
223 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Marvin
Marvin
Steve Allison
Steve Allison
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
