Question about General Time Corporation Westclox Bell Ringer Quartz Analog Bedside Alarm Clock The clarity of a bell alarm with the conveni...
Electric clock time runs fast
My clock worked fine until recently and suddenly starting gaining several hours in 24 hrs it is alarm clock only and says model 22651 on botrtom i could replace it with a new one for a few dollars but i have this overwhelming desire to make it work
  • Michael N Dec 17, 2008
    I have the same problem with 2 different LCD electric clocks. Both just started running fast, but not all the time. They can work fine for a day or so and the next thing I know one or the other is hours fast. I have tried them in different outlets and it doesn't make a difference. Someone told me it could be that the electric service isn't producing a constant 60 cycles. This can make some older clocks run fast- but they worked fine for years. Maybe I'll try calling me electric company to see if they have any idea what the problem could be.
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 | Watches
How do I adjust the clock when it's running slow?
If your cuckoo runs too fast or slow, the best way to correct this problem is to set your cuckoo to an accurate watch or clock. After 24 hours, record how many minutes your cuckoo is running too fast or slow. Then adjust the bob up or down the pendulum stick to change the pendulms effective length. You'll need to take an educated guess as to the distance. Reset the cuckoo minute hand time to your watch or clock again. Repeat this process every 24 hours, recording the results, and readjusting the bob until you are within 3 minutes of the correct time. Then, switch from recording every day to recording every week. Use the same process described, recording the time difference, adjusting the bob up or down every week, until the cuckoo is accurate within approximately 3 minutes per week. Remember, mechanical cuckoo clocks are not as accurate as quartz or electric clocks! A three minute error per week is not bad. Maybe you can do better. What you are attempting to do is to obtain is the best timekeeping possible from your cuckoo clock. Afterwards, you will still need to sychronize the cuckoo (coo coo) clock minute hand to an accurate clock or watch, each week or as desired.
Feb 14, 2016 | Audio Players & Recorders
How do I set the clock in the radio?
Typically, you have to hold down a "Time" or "Clock" button, then press either a fast or slow button and hold it until the display reads the correct time. Some models have hour and minute buttons instead of fast or slow, and a few have a slide switch that you move to the clock adjust position (it would also have an alarm set position) before the hour/minute or fast/slow buttons are enabled. Some clocks reset to 12:00 AM if you hold Clock, Fast and Slow all at the same time. You'll just have to experiment a bit to find out what works on yours.
Jun 25, 2015 | Audio Players & Recorders
Can not get the clock or alarm off the 24 hour clock!!! very annoying!!
  1. Try pressing the "MODE" button until the time setting flashes.
  2. Now press the "2" button (right under the screen) and simply advance the clock past 24:00 and the clock will enter 12 hour mode again.
  • Now the time and alarm will be in regular 12 hour time as well automatically.
  • If for some reason it is not then just reset the alarm by
  1. Pressing "MODE" until the alarm time and icon flashes on the screen.
  2. Press "1" to decrease and "2" to increase hours.
  3. Press "3" to decrease and "4" to increase
  4. Press "5" to select the alarm volume.
  5. Press ALM "OFF/ON" to activate/deactivate the alarm.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 25, 2011 | Sharper Image SI785 Clock Radio
How do I convert from military time to standard time?
Changing the clock time format You can choose to have the display show the time in 12-hour (AM/PM) or 24-hour (Military) time. 1. Alarm Time Menu Alarm Time Menu Tune Press and hold Alarm Time (Menu) until -SETUP MENU- is displayed. 2. Press Tune > three times until TIME- is displayed. 3. Press Time - or Time + to select 12 HOUR or 24 HOUR. 4. Press Alarm Time (Menu) to exit the setup menu or wait 10 seconds for the setup menu to end automatically.
I also have the pdf formatted Users manual http://products.bose.com/pdf/customer_service/owners/og_wrii.pdf
Oct 12, 2010 | Bose Wave Radio II
Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
Dec 12, 2008 | Sharper Image SI785 Clock Radio
Digital clock gains time
digital clocks work of the frequency input of the power source so it is possible to have it adjusted by a technician
like fine tuning a radio frequency there may be a pot that can be tuned to mains frequency exactly
talk with technicians in radio or tv shops or possible some jewellers who work on electric clocks may help
Nov 26, 2017 | General Time Corporation Westclox Bell...
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
General Time Corporation Westclox Bell Ringer Quartz Analog Bedside Alarm Clock The clarity of a bell alarm with the conveni... Logo
867 people viewed this question
Top General Time Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a General Time Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
