Question about Sony KP-53V75 53" Rear Projection Television
INSTALL NEW PC BOARD
I have a Sony 61 inch projection tv. The remote control does not allow us to turn off the tv or adjust the volume. I had this same dilema before. I previously had the warranty in place so the technician did all the work! I have purchased the new parts, however I do not know where they go? Can you please help? 1)HC Mountef PC board 2) Diode GP1U28Y Thank you, Juan
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Call tech ..to replace parts.
Posted on Nov 26, 2007
SOURCE:
Sony Bravia 55'inch led volume controls stopped working. Remote or tv button don't adjust volume
Volume is controlled by the main board. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix it yourself. It's easy.
May 10, 2017 | Sony Televison & Video
Dark -- background seems to dark with night time shows
To check your lamp useage hours: 1. turn on TV by touching the POWER button on the TV, not on the remote
2. press and hold CHANNEL DOWN and MENU on the TV
3. using remote, select "SERVICE ALIGNMENT (or something)" from the menu. 4. press VOLUME UP to V90
5. press CHANNEL UP If you have around 1500-2000 hours, then you'll need a new lamp soon. Don't wait too long... It will get dimmer and dimmer at an ever-increasing rate.
Jul 26, 2009 | InFocus ScreenPlay 61" Rear Projection...
Control of vertical TV image projected on the screen
You can try looking for 2 things
1. A button on your remote that says either: ARC, Ratio, 16:9, 4:3.... Some remotes have a picture of a square with arrows pointing out towards each corner..... I'm unfamiliar with this set, but it sounds like a widescreen, so give it a go
Apr 22, 2009 | Televison & Video
32 flat screen problem with remote and menu
Sounds like you need to get a Green Setup remote but if you are using this privately you will not be able to obtain one to program the tv. They are only available to hotels since the tv's are for commercial use.
Mar 18, 2008 | Philips Televison & Video
Sony rear projection tv kper43m31
All Sony projection TVs have the same remote key sequence to get into the service mode:
display - 5 - volume(+) - power
C-Dog
Feb 09, 2008 | Sony KP-61V90 61" Rear Projection...
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
The remote control just turn on the t.v
Does this model have the control buttons on top of the set? If so most of the time re-routing the cables inside the TV that go to that board solve the problem as high voltage static from the CRT cause issues with the micro. Or you might have one or more switches stuck or something spilled on them.
Mar 07, 2007 | Sony KV-32S26 32" TV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
TV turns off-on when I try to adjust the volume
check tact switchs ALL on the control panal. several with leaky switchs.good luck wayne
Oct 22, 2006 | Sony KP-53V90 53" Rear Projection...
Sony KP-53V75 53" Rear Projection Television Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
