Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
SOURCE: hi i have a dell
Hello
Press the Windows icon key on your keyboard, and hold it down until the "Start" menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl" and "Esc" at the same time.
Press "C," then arrow down to "Control Panel" and press "Enter."
Navigate to "Mouse" with your arrow keys, and press "Enter" to open up the mouse control dialog box. Then, press "Alt" and "F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device settings" or "Touchpad" or the similar option on your system, and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights, and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
SOURCE: My cursor on my Dell inspiron 1525 laptop is stuck
Try an external mouse. You might have to turn off the touchpad in BIOS (F2 key on boot will get you into setup). Look for Mouse/Touchpad under 'Post Behavior' or perhaps elsewhere (differently displayed in various BIOS setups).
SOURCE: turn off touch pad
When you are booting up from a cold shutdown, Tap the F2 key until you enter the Bios/System Setup Pages. Usually you use the Alt+P key combination to navigate in these pages, but there should also be a legend at the bottom of these pages to indicate what keys change pages. In these pages you will come upon your option to choose pointers. One is usually, glide pad + mouse. I'd try that first, as it senses when a mouse is attached and disables the glide pad. However, this doesn't always work with Dells. So, if that is the case, choose Mouse Only for a PS2 Mouse and or Serial for a USB Mouse.
The Glide Pad is found in the Control Panel, Mouse where you have a property tab that has the settings for your glide pad. Besides setting pressure sensitivity you can also disable it in some Dell Systems.
If none of this works for you, look on the bottom of your laptop for the Service Tag number and send that set of numbers and letters to me using the comment box below and I'll find you the driver update that should repair your Glide Pad.
As always, please rate all our solutions on FixYa.
Always here to help,
Worldvet
SOURCE: DIsable touch pad on Inspiron 1501 laptop with XP
In your system you should be using synaptics touchpad driver. First of all look for it under mouse properties in control panel. If its not there then install in from support.dell.com. Under this application you would be having option to disable touchpad when external mouse connected. Try this.
Please rate the comment
SOURCE: HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Replace the Touchpad
