Question about True GDM-12 Refrigerator Commercial
Not cooling
On my GDM-12 the fan is working however it is not cooling . Any suggestions
Have a True GDM 12, smelled burning believe it is the condenser fan. Is the fan supposted to be in constant motion? If the fan is not working doesn't it destroy something else?
Posted on Aug 12, 2009
    Problem Solver:
  • 19 Answers
It is more than likely that you are out of a refrigerant called R-22 hopefully that is all it is however the more expensive problem may be the compressor I had a problem with a kenmore refrigerator where the coils on the unit froze up I unplugged it for about 6 hours at room temperature about 70 degrees farenheit and it solved my problem however the general public cannot obtain R-22 you can buy the compressor and install it but the system must be relieved of freon (if any remains) it will save you time which is money when it comes to air conditioning techs the only thing they will have to do is fill the system up with R-22 good luck!
Posted on Nov 21, 2008
Noisy compressor?
My Gdm 12 was doing the very same thing. Remove the from grill plate by taking out the 4 screws below the door. This will expose the compressor mounting plate . While the compressor is running, and is at its loudest, loosen or tighten the two front hold down bolts until the noise goes away. Most likely, when you cooler was moved or transported off the shipping pallet, it was bent slightly allowing contact between the bottom of the compressor, and the mounting plate. Hope this helps.
Feb 03, 2014 | True GDM-12 Refrigerator Commercial
Dose anyone have a owners manual for a true refidgerator GDM-12
The fan your referring to is the condensor fan. it should not be tight to turn. it should spin freely. if it is hard to turn, its probably stuck, which is why its not spinning. Remove grill, slide the nottom portiom out so you have access to fan, remove fan blade, and spraylubricant on fan motor (around the area that the screw that held blade). Remove hair, dirt, string, or anything else that might be prevrnting fan from spinning. sometimes its easier to burn it off. If fan still doesnt spin you may have to replace fan motor.r
Sep 26, 2012 | True GDM-12 Refrigerator Commercial
I have a True GDM-26. The contents get cool inside but not cold. The temperature dial is set at the coldest setting. Also, there is a lot of condensation on the bottles inside the cooler. Any...
I have same problem was told condensing fan not working properly. Easy to see if this is the problem, take out guard in front of machine and put a fan blowing into it. I went to home depot and bought a tornado fan and it cools again. Now if I can only figure out if its the fan or whatever contros its speed. If anyone knows how to check please respond.
Nov 24, 2009 | True GDM-26 Refrigerator
True gdm-12, condenser fan
should not be on all the time only when it is cooling.. make sure your fan and blades and condensor are clean this will make your fridg cool better and run less should be cleaned at leaste once a year.....
Aug 12, 2009 | True GDM-12 Refrigerator Commercial
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
Commercial TRUE GDM soda machine
If the cooler has power, the condesor fan (bottom) and evaporator fan (top) are spinning put your hand on the compressor. Do you feel a vibration? if so, you probably have a refrigerant leak. If not (if its clicking or nothing at all) its a compressor issue.
Dec 05, 2008 | True GDM-12 Refrigerator Commercial
Gdm-12
GDM-12 refrig not cooling
Jan 19, 2008 | True GDM-12 Refrigerator Commercial
True GDM-12 Refrigerator Commercial Logo
404 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
