Question about Apple iMac 24" Desktop
My new Imac won't recognize my cannon zr65 camcorder help please.
I know the firewire ports are working I've tested them out, I know the cable isn't the problem I've hooked this camera up to my PC, with no problems. For some reason the mac also knocks off my Lacie harddrive when I hook up the camcorder. I've tried powering down and up again with everything hooked up. No luck. When i have the camcorder hooked up and check Mac settings it says it's a undetectable device.
  • davesun2000 Mar 27, 2009
    I have the same problem in imac not recognizing my zr600 video camera.
    I mainly got this imac for this purpose.
  • 11 Answers
Some FireWire cameras do not play nice with other FW devices. Try unplugging the LaCie drive and any other FireWire device, then connect the camera directly to the Mac. iMovie should detect it then.
Posted on Nov 27, 2008
I can not get my iMac, running on OS x 10.8.5 to recognize my Panasonic PV-GS85 camcorder. Tried installing converters but they can't detect a camcorder either. ANy solutions? Any help would be highly...
You will need to capture using a firewire cable.
If you are using a firewire cable and it does not work try another brand of cable as some have a reputation for not handling DV capture.
Al
Oct 18, 2013 | Panasonic PV-GS85 Mini DV Digital...
SONY DSR PD 170 OR 170P IS THE CAMERA MODEL AND LAPTOP IS SONY VAIO VPCEG18FG. The camera has a DV firewire port and lap top has only 3 usb ports. I tried connecting it with a cable that ha s firewire...
This Camcorder does not support USB streaming with the Windows 7 Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.The Firewire to USB cable won't work with your camcorder,you will always end up with this error.
Click the link below for the instruction to transfer the video to the Computer using i.LINK cable.
>> http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
You Sony vaio laptop doesn't have firewire ports ,in this case you will need to purchase and install an firewire card ..>>
see link >>
http://www.ramelectronics.net/computer-parts/computer-accessories/firewire-i-link/firewire-cards/29972/prod29972.html
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Please let me know if you need further assistance on this issue .
Nov 13, 2011 | Video Cameras
I bought my camera used online. The DV cable input does not work. (Unfortunately I was not told about this problem.) I cannot pass the tape to my computer now because of the DV input problem. Does...
I recommend you, test the cable, the Firewire ports. test connection.
Plug the firewire into the camcorder BEFORE turning it on,
You must use a Firewire cable and FW ports (Firewire to Firewire) NOT USB port
Check the cable no bend.
1.- Try with other cable
2.- Try connect a different Firewire port on your PC (or connect to other PC)
3.- To test the FW port on your PC connecting other devices by example external hard drive
If the Hardrive work fine the problem is with your camcorder
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Panasonic DVX-100 Camcorder
Hi, I've always been able to connect my Canon MV4i MC camcorder to my computer (Windows XP) via the Firewire port. However, I've just bought a new computer (Windows 7) which has no Firewire port....
Why have you bought a 'new' computer with such an outdated operating system ? Have you an available expansion slot on the motherboard to install a Firewire card ?
Jun 23, 2017 | Canon MV4i Mini DV Digital Camcorder
Hi, I 've got a Handycam Digital 8 (DCR-TRV270E) and Windows Vista Home Basic and have lost the software for my camera and my PC doesn't recognize the device when it's imported to usb port. How can I...
Are you connecting using USB or Firewire? Unfortunately there are no USB Windows Vista drivers for your particular camcorder but using a Firewire(i.link) Cable should work. For further reference here is the support site for your camera. Camcorder Support Site
Mar 05, 2011 | Sony DCR-TRV270E Digital-8 Digital...
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
Imac 9pin firewire port does not recognize my Sony DCR-HC52
Perhaps a USB to Firewire dongle will help sort you out. As you have discovered those two are not compatible. To make it work, you MUST get a 4 pin card and install it, or the USB solution.
Mar 14, 2010 | Video Cameras
I have a Canon FS100 Digital Video Camcorder. I am attempting to download some video on to my iMac, but then I select "Connect To Camera" I get the message "No Camera Was Found". I have the camera plugged...
The computer is no longer detecting the camcorder for several reasons. It could be the ports on the computer, it could be the cable that you're using to connect the camcorder to the iMac, or it could be the camcorder itself.
Try connecting the camcorder into different USB or FireWire port of the iMac.
Try using different cable.
Try connecting the camcorder into different computer to test the device.
If all else fails, power cycle the camcorder by turning it off and remove the battery for about 10 minutes. Then turn it back on. Otherwise, contact the manufacturer for second opinion.
Hope these helps and have a great day!
Aug 12, 2009 | Canon FS100 Flash Media Camcorder
Cannot download video, only Card pictures
I do not know MACs, but a standard 4-pin to 6-pin firewire (IEEE1394) is needed. On Windows XP, plug it in, run Windows Movemaker and you are good to go. By the way, a "DV cable" is a firewire cable.
If your MAC cannot "see" your camcorder, try another firewire device to see if your MAC is the culprit, or drag your camcorder and firewire cable to a friend's PC running Windows XP and see if it works.
May 27, 2009 | Canon ZR70MC Mini DV Digital Camcorder
Cannot connect to Computer
Turn off computer. Turn ON computer and immediately hold down Apple+option+p+r. after 4 chimes let go. You are going to be using the Firewire cable. once the camera is on and plugged into computer go to : apple> about this mac> more info click on Firewire. on the right hand side you should see your camera. Now if you don't its either the Firewire port on camera or the cable it self. to further isolate. Get your older computer. leave off. plug the firewire cable into both computers. Now the older computer that is turned off. TURN ON and immediately hold down the " T " on keyboard. ON the polder mac, your screen with have like a "Y" icon.. its a Firewire icon. Now look on the other computers desktop, do you see a yellow or blue hard drive on desktop. IF you do.. ITS your camera because we just tested your cable and both ports and they are working. Now try the USB cable and see if its detected by computer by going back to Apple system profiler and see if the computer is detecting it
Mar 24, 2009 | Sony Handycam DCR-TRV18E Mini DV Digital...
Apple iMac 24" Desktop Logo
496 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
