Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Constant Humm / Buzz but Works OK
After just a few hours of operation, we started to notice a faint humming/buzzing sound. It is a little louder when you open the door. Seems to be coming from the left side. All microwave functions seem to work AOK. Cooks fine too, but the high pitch is too much to bare. I tested the H.V. Diode and it checks out OK. Thanks!
  • Ronnie Pinkerton Dec 22, 2006
    Turned out to be the L.V. Transformer. Replaced for $50...
  • KitchenAid Master
  • 9,098 Answers
I was going to suggest the low voltage transformer, but when you said it sounded like it was coming from the left side, that seemed odd. I have a stock transformer here I keep for test that is loud, but it works. Odd, eh?
Posted on Dec 22, 2006
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Hello, i own a 7year old advantium oven everything works except the microwave, the key pad and timer shows its on but wont heat. any suggestions thanks
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If it sounds the same as usual or a little louder, I would suspect the magnetron or high voltage diode has failed.
If it is much quieter than usual I would suspect a bad upper door switch.
The service manual is here.
Also see this file on door switches.
Aug 22, 2010 | GE Advantium 120 Convection/Microwave Oven
Everything works exept the heat. Thought we had a power surge a few days ago?
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
Note that a
full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Nov 23, 2009 | Kenmore 80593 Microwave Oven
Buzzing (a little bit louder than normal humm), but no popping
WHEN THERE IS A BUZZING NOISE IT MEANS THAT ONE OF THE INTERNAL COMPONENT HAS FAILED .RANGING FROM A SMALL DIODE TO LARGE PARTS LIKE
THE MAGNETRON OR TRANSFORMER OR CAPACITOR. IF IT IS 10 YRS,OLD YOUR BETTER
OFF GETTING A NEW ONE .BECAUSE YOU COULD INVEST MONEY IN THIS ONE AND HAVE SOMETHING ELSE GO TWO DAYS FOR NOW.WITH A NEW ONE YOU ALSO END UP WITH THE NEW WARRANTY. HOPE I HELPED. KEN62 GOOD DAY!
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
Maytag CMV1000BAW microwave doesn't heat
Probably a bad mag, if the transformer goes bad it will draw a lot of amps and blow the fuse. If a mag shorts it just makes a more pronounced hum. Same with the rectifier. If you Ohm out the rectifier it should show open both ways as it is a really high resistance and the only way it would make a louder hum is if it shouts. so If it looks open it is probably OK, and probably bad mag. .
Aug 11, 2017 | Maytag Microwave Ovens
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
336 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
