Question about Encore ENHWI-G-RLAM 4-Port Wireless-G 54Mbps Router
Which holes do the cables go in ?
Have unplugged both cables from back of router & cannot remember which goes where
  • 120 Answers
The cable from your service provider go in the uplink port (usually a different color or port 1). The others should not matter as long as they are connected.
Posted on Nov 21, 2008
MY LAPTOP AND PHONE BOTH FIND MY ROUTER BUT WIIL NOT CONNECT, ALL THE LIGHTS ARE GREEN ON ROUTER! I'VE TAKEN THE ETHERNET CABLE OUT MY PC (PC NOT TURNED ON FOR A YEAR!) AND CONNECTED IT TO LAPTOP AND...
It is possible that there are restrictions on your wireless router, do you remember setting up a password? Anyway, to completely remove any restrictions from wireless connections, just reset your router. To do that you need to do the following:
•Unplug all LAN cables from the router.
•Unplug the router power cord connector from the back of the device.
•Using a paper clip or something similar that will fit into the reset hole, press continue to hold the reset button, then carefully reinsert the power cord, making sure not to release the reset button in the process.
•Continue to hold the reset button in for at least 15 seconds after inserting the power cord, then release it. After about 10-25 seconds the router will boot and it will be set back to the original factory default settings.
By default the password on the router is left blank, and the default IP address is 192.168.2.1
I hope this will solve your problem.
You can rate my answer if this helped you.
-damneddle
Oct 06, 2011 | Belkin (F6D42304) Wireless Router
Tip
My _ quit working on my laptop/computer. (fill in the blank)
After 28 years of troubleshooting computer systems, I have a tip for all of you non-technical types... that have an issue and don't know where to start.
  1. Before you call a tech, pull out your hair or take your computer to the dumpster, follow these simple steps.
  2. Turn off the computer.
  3. Unplug the computer. (If you have a laptop then you MUST also remove the battery.)
  4. Power all devices off. This means everything. Every Printer, Monitor, USB Device, Mouse, Keyboard, Phone line, Modem, Router... everything that has batteries, a power cord or plugs into the computer. (ONLY after turning the computer off and unplugging it.)
    Helpful Hint: If everything is plugged into a surge protector, turning OFF the surge protector is the SAME as unplugging. This saves time and effort also. You MUST unplug the computer itself though, without fail.
    Helpful Hint: If you are concerned you will NOT remember where to plug something back in, get a pen and some masking tape or a sticky pad and label them... (ie: place a 1 on the tape and put it next to the hole and then put a 1 on the cable that goes in that hole) DON'T WORRY! Most devices that can plug into more than one place won't mind if you move them. Most are color coded already to make it easy to find where they go. (blue plug goes in blue hole, etc.)
    Double Check: Once you are sure everything is off, make sure that any phone lines or cords from modems or routers are unplugged. Anything that can or might supply power to the computer... unplug. If you see a green light on the back of the computer, something is NOT unplugged.
  5. Count to 300 or simply wait 3 minutes for all devices to discharge. Plugging them back in right away defeats the process. (Patience here, allow proper time... make a sandwich, call your Mom, pick your nose, just wait at least 3 minutes.)
  6. Plug in any cables you have unplugged in reverse order. (ie: We turned the computer off FIRST and unplugged it FIRST so we will plug it in LAST)
  7. Turn on the power to all devices (NOT THE COMPUTER ITSELF!) and make sure they are re-connected to the computer.
    Double Check: Make sure all devices are re-connected and have power.
    IMPORTANT!: It is very important that you plug in and turn on ALL devices BEFORE you plug the computer in. Ensure that everything (printer, mouse, monitor, USB devices, Router Cable...etc.) is plugged in and turned on before you place the power cord into the computer.
  8. Plug the computer in. (replace the battery also if it is a laptop, unless the problem IS the battery)
  9. Push the power button and start the computer.
    If I had a nickel for every time that following the above steps resolved a computer problem, I would rival Bill Gates in my wealth.
    Many devices constantly supply power to the computer motherboard and allowing them to discharge can alleviate minor hardware issues.
    If the above steps do NOT resolve the problem. Do not attempt to fix it yourself or from instructions you find on the Internet. Call a technician immediately and tell them everything that you were doing when the problem occurred.
    Computers are the most excellent tool we humans have created and they will work for years without issues IF they are set up and maintained correctly. Remember to have a tech tune-up and clean out your computer at least once every 6 months and Happy Computing!
on Sep 07, 2010 | Computers & Internet
What does ps3 error code 80130182 mean?
80130182 means it can't connect to the internet Basically. Here is what you do:
Unplug everything from your router.
Unplug everything from your modem, even the cable.
Remember where everything goes.
Plug it all back in. Switch on again
Sep 27, 2011 | Sony PlayStation® 3 (80GB) Console
I can't sign in to playstation network error 80130182 keeps coming up
It Appears U Have Something Wrong With The Network Try These Steps Unplug everything from your router.
Unplug everything from your modem, even the power, cable.
Plug it all back in after few minutes
Jul 22, 2011 | Sony Playstation 3 (PS3) Console
Error code 80710102
Unplug everything from your modem, even the power,cable.
OR
http://community.us.playstation.com/thread/1593193?start=0&tstart=0
I have error code 80130182 on my ps3 and can no longer connect to the internet or go on line
Found this on another site. Hope it helps:-
80130182 means it can't connect to the internet, basically.
heres what you do.
Sep 23, 2010 | Sony Playstation 3 (PS3) Console
I cant remember my login or password. how do i reset these?
on the back there should be a little hole with reset above it, Get a paper clip or pin and push it in the hole and you will feel a button click in.
Kept it hold down for about 10 seconds and you should see the lights start flashing and your router is then reset. If it doesnt reset the first time, try holding the reset button in a bit longer.
Good Luck :D
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
I can't remember my user name and password to my router
You will need to reset the router. On the back of the router hold down the reset button for 30 seconds release the button and then wait for the power light to stop blinking. If it doesnt stop blinking within 1 minute unplug and wait 30 seconds plug back in and the router will be reset
Feb 15, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Loosing linksys Router instructed cd to set up
Have had many time problems with the router:
Do the following: If you have a router and a linksys modem do it to both.
Disconnect the power source from the router and disconnect the ethernet cable wait about 30 seconds .. plug back in the power sources (do not just pull the plug that goes into the wall...... remove the black little cord that plugs into the router)
In some cases (if the above doesn't work the first time..) you may also want to completely unscrew the coaxial cable from your broadband provider ) and wait 30 seconds or a minute and follow through with the unplug resetting..
Note: there are also reset features on the back of your modem and router.. it never hurts to use those once in awhile
on router.. there little button that pops out in the back .. just hold it in for 2 0r 3 seconds and release..
on modem... SEE that tiny little hole between the power supply and the ethernet plug.. carefully insert a paper clip into the hole..no you won't get electrocuted.. and GENTLY push the reset ...
Hope this helps.
walrus4425
Apr 17, 2008 | Computers & Internet
Plug me in!
The ethernet cable that goes from the modem goes into the router's port labeled "internet." The other ethernet cable going from the computer goes to the routers ethernet cable port labeled "port 1."
Apr 14, 2008 | Linksys Wireless-G Broadband Router
Encore ENHWI-G-RLAM 4-Port Wireless-G 54Mbps Router Logo
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
