Question about Whirlpool Duet GHW9150P Front Load Washer
Soap dispenser overflows and leaks onto floor
This is a problem that seems to occur sporadically, as if a valve is getting stuck. When it happens the water comes pouring out from the inside front panel, not the door. Can anyone elnlighten me on how to solve this problem?
  • d2kaiser Nov 25, 2008
    We leave our door open so the tub will dry completely and not start to smell. Tonight we came home and water was all over the floor. The tub was full of water and overflowed out the open door. I drained it and looked inside to find a constant trickle of water coming from the inlet from the soap dispencer (top left side of the big gasket that seals the door). Why would this water flow be constant if the hose was clogged with debris? Will definately be shutting off the water flow to the washer from now on.
    President:
  • Whirlpool Master
  • 2,651 Answers
Ive seen that somehow somehting gets down inside the dispensor itself, ( fabric sheet, wash cloth, pull tab from bew detergent, and if this happens it gets down inside he fill tube blocking off te waterform entering machine and backs up through the front. by removing hte top of machine (3 screws across the back) youll see the dispensor box located in left front corner, look for the hose on the bottom leading to the front of the tub assy and look inside for debris
Posted on Nov 23, 2008
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Leaking
hello there
Although there are a few leaks common to all brands, most brands have leaks that are peculiar to their design. GE, Whirlpool, Maytag, and others all have common and well-known leak areas. After reading this section, see the chapter about specific brands for details.
A common "leak" zone is not a leak at all; the wall drain backs up and overflows onto the floor. This is commonly misdiagnosed as a leak. It can be difficult to diagnose; the problem may be intermittent. Depending on how badly the drain is clogged, there may be a little water or a lot, or it may only overflow every second or third load. While diagnosing a leak, do not be too quick to write this diagnosis off.
If you suspect that your drain is backing up, but you can't quite ever be there at the right time to observe the overflow, try this: wrap some toilet paper around the drain hose just above the wall drain pipe. If it backs up, the paper will get wet. Even if you're not there when it happens and the paper dries out, it will have crinkled up, and you'll know your drain's backing up.
If it isn't the drain, run the machine with a full load. Without moving the machine, get right down on the floor and look under the machine with a flashlight. Try to find the general area where water is dripping to the floor; front or back of the machine, left or right side.
Open the cabinet and look for mineral or soap deposits where there shouldn't be any.
Trace the deposits in the natural direction of waterflow (against gravity or centrifugal force) back to the source of the leak. Fill the machine again and run it through a cycle or two. Be patient; use your eyes and your brains. There is no magic, easy way to detect a leak.
The usual places are:
WATER VALVE: The guts of the fill solenoid valve sometimes will corrode. You may see water leaking from, or rust on the top of the solenoid. (See figure G-7A) Since the valves only open during a fill cycle, this may appear as an intermittent leak. The solution is to replace the valve.
PUMP: Usually from around the pulley seal. Some washer pumps have a hole that allows water to weep out when the seal starts to go bad. The solution is to replace or rebuild the pump.
BLEACH DISPENSERS: Bleach is VERY hard on plastic parts. If the bleach dispenser gets old and brittle, it can crack or break off, and the flush water can leak out.
Figure G-7A: Leaky Water Solenoid Valve
Oct 16, 2010 | GE WVSR1060A Top Load Washer
My ge potscrubber 650 is leaking onto the floor in front of the dishwasher. What is the likely problem?
Check you filter and screen .Check whether you need an replacement for them.
If you dishwasher has foam coming out from under the door, then the problem is that dish soap somehow ended up in the dishwasher or excessive rinse aid . It is not recommended to prewash the dishes before loading them into the dishwasher as only a small amount of dish soap can cause the sudsing that you experienced. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used. Spilling rinse aid while filling the dispenser will cause sudsing also.
To clear the suds from the dishwasher sprinkle several tablespoons of non-dairy coffee creamer over the suds. The fat in the creamer will help break down the bubbles. Wait five minutes for the suds to lessen.
Many pump leaks happen around the seal on the pulley. Some pumps have a weep hole that lets water drip out when this seal begins to go bad. The solution is to rebuild or replace the pump.
You'll want to confirm that the fill hoses are connected and properly tightened. Always use new rubber washers when re-installing the hoses. Take care not to over-tighten the connection. Other leaks may be caused by the drain hose being cracked, or by a leaky connection at the water-inlet valve. Too many suds may cause the appearance of a leak when actually it's just a sudsy overflow. Sometimes a drain hose leak occurs at the end of the hose where it attaches to the washer. If the hose is long enough you can cut the leaky end off and re-clamp the hose back on. Usually though, when a hose begins to leak, it is best to just replace the hose.
Sep 10, 2010 | Dishwashers
My front end loading washing machine when the water goes into the dispenser it doesn't go down the hose and comes out and leaks onto the floor?
most of the time when this happens the hose going into the tub is blocked with soap so the dispenser overflows have a close look and clear the obstruction also check for split or loose hose hope this helps you
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
LG WM-2277HW Water overflowing from soap drawer (compartment)
look for port inside top area of basket where water comes in may be plugged with same junk found in pump
May 28, 2008 | LG WM-2277HW Front Load Washer
Steamvac drips when tilt to pull back
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Feb 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Whirlpool Duet GHW9150P Front Load Washer Logo
340 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
