Question about RCA CC6373 Camcorder
Error message E03
The model number is CC6373 (RCA). We just used this camera 2 days ago, same battery, etc. Last night when we tried to use it, it came up with the message E03 unit is safeguard mode, remove and reattach the battery. We did this several times and can't resolve this problem. Any suggestions?
  • Nanlus Jan 10, 2008
    I have a RCA Model CC6373 that gives me an error message "EO2 Unit in Safeguard Mode. Please detach and reattach battery. Have tried to get the problem resolved but cannot figure out what it could be.
    Nannette
  • slatoja Mar 24, 2008
    i have the same problem with this. unit jvc gr-sxm240u. anyone can help me out with this. thanks
5 Suggested Answers
kala
  • 156 Answers
SOURCE: JVC safeguard
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shift.
3. No power is supplied to the loading MDA.
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the loading direction for 4 seconds
or more. This error is defined as [E01].
Posted on Mar 12, 2008
57 varieties
  • 1653 Answers
SOURCE: E03 safegaurd mode remove and replace battery? how
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solve the problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC’s and Panasonics and servicing (which may be costly) or scrapping is the only resolution.
Posted on Oct 06, 2009
SOURCE: WHEN I TURN IT ON KEEPS SAYING UNIT IN SAFEGUARD
Sometimes there is a reset button.
Posted on Aug 23, 2010
  • 19 Answers
SOURCE: On RCA CC9360 I have
http://www.digital-camera-battery-charger.co.uk http://www.battery-charger.us http://www.power-jack.net/ We are committed to the laptop battery, digital camera batteries, camcorder batteries, PDA batteries and Chargers, development, production and marketing services, the products sell well not only 11 years in Europe, America, Korea, Taiwan, Hong Kong and Southeast Asia and other countries and regions, but also through all major cities across the country to establish a sales agent in the form, the establishment of a comprehensive sales network and after-sale service system, the first class products and perfect after-sales service to consumers.
Posted on Aug 05, 2011
Hello sir, I have olympus C-70 model which is working very good for last 5 years. I am on vaction to france and it worked well till last 2 days. I have switched it off 2days back and switched on last night...
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Aug 23, 2009 | Olympus Cameras
DVL315 Did get hot NOW Error E03 Showing up
Take the battery out and leave it somewhere cool (not cold - over 10 degrees C) for 24 hours - this may help.
Jun 13, 2017 | JVC GR-DVL315 Mini DV Digital Camcorder
Error code E03
Hi. It could be bad. Your battery has probably failed long ago, and it needed to use it when the power went off. try this:
Turn key to PROGRAM mode.
Power off at wall.
Hold RECEIPT FEED down while turning power back on at wall.
Wait 10 seconds.
Let go of button. You should see 'FFFFFFFFF' on display.
Press SUBTOTAL
Check the printout. Look under the copyright at the bottom right, and you should see a number e.g 10801 or similar. If it's all zeros, you have lost everything, and it will need to have the batt changed and fully reprogrammed. Otherwise, turn to REG mode, and try it.
Mark
Apr 05, 2008 | Casio Parts Cash Register PC Desktop
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
Error E03 -
I tried Tapping on side of Camcorder and I worked, after 2 or three times while message appeared.
Oct 19, 2007 | JVC GR-DVL100 Mini DV Digital Camcorder
Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Mar 19, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Weird error message
For Models: CC6254, CC6364, CC6374, CC6384, CC6394, CC9360, CC9370, CC9373 There may be a simple solution. Do the following: * Turn your camcorder's power off, then disconnect the power source (battery or AC adapter). * Remove the clock battery, if equipped with one. * Wait a few minutes, then reinstall the clock battery. Reconnect or install the power source — battery or AC. * Then try turning on the power again.
Sep 06, 2005 | RCA CC-432 Camcorder
RCA CC6373 Camcorder Logo
62 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
