Fabric softner wont go in the tub from the top dispenser properly
When you put fabric softner in the dispensing slot it never fully empties when it is supposed to. Intermittent problem. Fabric softener is not added to rinse and remains in dispenser at end of cycle. We have fully dismantled and cleaned the unit but does not help. Have also diluted the softener (I use Downy). Because its intermittent I don't think there is a blockage. I entered a valid product below according to my paperwork - but it is not accepted (Frigidaire Front Load Washer Model GLTF1040AS - is correct!)
  • przhim4mykdz Dec 03, 2008
    I have the exact same problem. Love my machine, but this is frustrating.
  • Anonymous Dec 05, 2008
    same thing here
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
SOURCE: fabric softener does not despense
I had the same problem with mine, and just added water in with the softener to fill it 'to the line' - and it's worked since!  Can't hurt to try!!
Posted on Jan 20, 2008
SOURCE: Fabric softener not draining during rinse cycle
What type of water hoses are hooked up to it? If you have the flood safe hoses with the check valve in them then there isn't enough water pressure to distribute the softener.
Posted on Jun 11, 2008
THENTHEREWER
  • 131 Answers
SOURCE: fabric softner wont go in the tub from the top dispenser properly
try thinning your fabric softner with a little water,the viscosity of some is higher than others. (this is how thick it is & varys by brand)i think you will find with a little trial & error this will solve the problem.if not,then contact us again & we will try another option.hope this helps & thanx again for using fix-ya .please rate all replys & again thanx.
Posted on Nov 16, 2008
  • 38 Answers
SOURCE: kenmore 44082 washer won't take in fabric softener
Remove hoses from fill valve, clean screens inside fill valve, if this does not fix problem, replace valve.
Posted on Mar 08, 2009
Where do you put fabric softner
Manually: If you're adding fabric conditioner by hand, be sure not to add it during the wash cycle. The washcycle will clean away much of the softener, so add it during the rinse cycle. Also, try to avoid direct contact with fabrics to avoid stains; instead, pour Downy into the deeper pockets of water.
How to Use Fabric Softener Without Dispenser ' Downy
where do you put fabric softener in the washing machine Google Search
Oct 30, 2017 | Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
The fabric softener dispenser will not empty on my Frigidaire FTF530FS.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Feb 24, 2011 | Frigidaire FTF530FS Front Load Washer
The fabric softener is clogged with dried up fabric softener on my Whirpool Washer. How can I get it cleaned out?
You really cant take them apart without breaking the dispensers. Fabric softner is basically wax and fragrance. Add very hot water to the dispenser to melt the fabric softner. In the future, water down the fabric softner.
Feb 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
The softner dispenser will not empty. then has bad smell.
if this is a front load washer you need to raise the top and check all the dispenser hoses for clogged, hardened fabric softener. if you only wash in warm or cold water, the hoses will get built up with soap and fabric softener. you need to do at least one load of hot every month to keep the hoses cleaned out, the hot water disolves it better. as for the smell you can buy a product called AFRESH and follow the directions on the package and routinely use one tablet every month for the odor. if there is a lot of water in the tub, you may have something caught in the impeller of the drain pump. hope this helps.
Nov 07, 2009 | Kenmore Washing Machines
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
Dispenser drawer and tub
softner dispenser has pushed down into the dasher. How to take off top of dasher to replace the small softner dispenser cup that was pushed down.
Apr 13, 2009 | Washing Machines
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
