Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Akai PTH5498 54in, red and blue all over the place.
I have double images, and the red and blue are all mixed up, I tried setting the Red Convergence but nothing happens, the book says to use the remote, but when I try this nothing moves. I can?t set the Red or the blue. Is there a problem with the convergence not working? This just started this, and now I have no way of setting the convergence. Any help will be greatly appreciated Thanks Pete
  • smusz8 May 07, 2008
    Have red lines (thin) and wavey that go from left top, drop down then go back up to top right. On the bottom there is dubble and curved words and piture. tried the covergence but only helped a little. Where is the auto focus button?
  • Anonymous Jun 09, 2008
    I have a 4" black strip that go across the bottom of my screen. the picture looks like it has move up leaving the black strip on the bottom of the screen
I have seen this problem before. Look at the convergence amp. section of the set. at the bottom of the heat sinks . there are 1 fuse at the bottom of each on the board they look like resistors they are 3.5 amp fuses, i believe, that blow. no way to tell except with a meter. try this first if it works you got it, if not truy replacing the amplifier ic's and fuses again if they blow. Good luck
Posted on Sep 26, 2008
    Problem Solver:
  • 16 Answers
If you cannot correct the problem in the customer conv adj menu, or by pressing an auto focus button, then you have a defect in the convergence circuit...don't attempt to enter the service menu (the other guy has incorrect info) You'll only make the repair more difficult for the trained technician...Good Luck
Posted on Oct 01, 2007
The code is mute 183
Posted on Sep 19, 2007
I had the same problem. you have to type in a code to bring the color grid up then adjust them left right up or down...But I lost the code and i need to do it again. So if anyone knows the code it will help us all out. It was something like mute-0-8 then click 7 for red and so on but I cant remember. I got the info from a downloadable repair manual it was very is to understand and read.
Posted on Aug 21, 2007
Double image and 3d color
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 17, 2010 | Sony KP-43T90 43" Rear Projection...
Double Images Too much Red and Green
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Dec 03, 2009 | RCA D56W20 56" Rear Projection Television
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Double image on my Sony KP 43t90
  • Screen looks 3D
Feb 22, 2009 | Sony KP-43T90 43" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Double image
yes you just need two ICs
Jul 12, 2008 | Akai PTH5498 54" Rear Projection...
Double image
If your model number is the PTH5498 you will need to replace both convergence ICs they are stk 392-040 you can get replacements at the followig link and they will provide fre instalation instructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Jul 11, 2008 | Akai PTH5498 54" Rear Projection...
Seeing double image in three colors
Its a convergence problem for sure ,,,if you cant move the red or blue (green is stationary) then your problem lies on the convervence module.. requiring ....mostly new output ICs like STKs your going to need a tech, for convergence is a common problem with rear projectors and requires patience and a expert to get it back just right. good luck
Sep 01, 2007 | Akai PT4298HD Rear Projection Television
Convergence Issues
I a having the same convergence issues. What is the crt he said to replace?
Dec 27, 2006 | Akai PTH5498 54" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
174 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
