Plugged laptop into power, press the turn on button and only get a power light blink.. nothing comes on even on external screen. I have tried a ram resit so thats not the issue..
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the battery, remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
SOURCE: dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
SOURCE: Dell Inspiron 1000 notebook won't turn on
The motherboard is bad. This model had a fault where after a while the North Bidge heatsink would break off and short the motherboard distroying it. This problem is something to not fix, it is not worth it, cost more than it is worth.
SOURCE: dell precision m60 press the power button the
You could have a bad peice of memory or a bad memory slot. Pull the memory out and try one peice at a time in each of the two slots. If you only have 1 peice you will need to either borrow a peice of the same memory or buy it. You also could have a shorted battery so pull the battery out if the ram is ok and try to boot. Another idea is the cd rom may have a problem so pull it if the ram and battery are ok. After doing all this if the system will still not boot the motherboard must have a short and needs replacement. This model also had an issue with the power board where the power button is. The connector on the motherboard was poorly designed and very sloppy. Over time it gets worn and causes a similar issue. The temporary cure is to press very hard on the power button to see if it will boot and then leave it running. You can also put pressure on the underneath side around the docking port and press the power button. This issue however requires a new motherboard. The M60 is almost the same as the D800 infact most parts are interchangeable. You could switch out the motherboard to a D800. I refurbish the D600 AND D800'S daily so I am fimilar to this issue. Let me know how you make out. Phil [email protected]
SOURCE: power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
SOURCE: Blinking Lights, Computer Wont Boot
If it's blinking 9 times then it's likely telling you one or more of the RAM sticks are in need of replacement. To check these, remove the laptops power cord and battery, then locate and remove, the cover for the RAM. Remove one chip at a time and try booting the laptop.
