Question about HP DeskJet F380 All-In-One Printer
My labal for CD are not line up wright, How can i fix that
When i make a CD i can not put a labal on it because the labal is off set.
  • 1 more comment
  • delbertlipsc Nov 21, 2008
    Yes : The labal print is misaline
  • P. Thomas
    P. Thomas May 11, 2010
    ok..well..then that is from a printing issue..do you print those on some special printer? can you supply the model of that printer, and also the type of software used to make that cd label?
  • P. Thomas
    are you saying the print on the label is misaligned, or the label is offset when placed on the cd?
Lost my cd
Posted on Nov 21, 2008
Everytime i put my camrea on it says ''wright project'' how can i get it off
You declined to specify what model Olympus camera, so I'm assuming it uses SD/SDHC cards. I'm also assuming it actually says "write protect."
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 20, 2012 | Olympus Cameras
My tv starting fading out a couple months ago. I can see some of the picture, but it doesn't fill the whole tv screen. Can it be fixed?
Yes,now turn on the tv started fading out with white lines on the tv CRT-(tv tube) wright?Tv still have audio sound wright?Tv set have cold soldering joints on it tv video board socket holes joints back of the tv video board connections between CRT-(tv tube) and the tv video board.U have some tools like a soldering iron and a role of solders and u can do basic soldering work wright?Take the tv aparts and resolders the back of the tv sockets holes joints of the tv video boad for a good connections between video boad and CRT-(tv tube).Or take to the tvs shops tell them this,if they're not try to cheat u they charges u like $30-35 take the tv aparts and resolders the tv video board back sockets holes connetions joints between the tv video board and CRT-(tv tube) for u.The whole jobs don't take more than 20-25 mins.
Aug 31, 2011 | TruTech T2000FT TV
How do you assemble the stand to the tv
This is a pretty easy job.U have the four Philip screws that came with the tv base stand wright?U have a Phillip screw driver wright?Just put the base stand into the tv make sure all the screws holes lines up between the tv and the base stand holes.Than just tighten the Phillip screws with the Philip screws driver,than u are done.
Jul 14, 2011 | Samsung LA40A450 40 in. LCD TV
Sony KP51WS510 seven years old - have double image.
Ur tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair by replacing 2 STK convergence ICS and some or all of it resistors too.To fixed tv 3D or misalignments R,G,B colors lines tv picture.Are u willing to put in another like $300-350 for tv shops to fixed?That what it will cost for parts and labors by a professional tv tech. to do the job wright.
Jun 12, 2011 | Sony KP-57WS500 57" Rear Projection...
How to wright proctected cd burn
hello,
try for soft key reveller.
or
try to burn the cd using power iso software. then copy that image to the required cd
thanks
May 09, 2010 | IBM Microsoft Windows XP Professional for...
Is there a timing diagram? I need to put the timing chain back on.
remove the right hand inspection hole from the engine cover turn the engine over with bolt in the hole and set the mark to no 1 tdc on remove the cam chain tensioner set the inlet cam with the inlet line mark flush to the head were the cam cover would sit then set the ex cam flush with the ex line and check that all three marks line up :inlet flush with the head the same with the ex cam and the crank mark lines up with engine case no 1 mark bolt down the cams in a criss cross pattern and torque to 12nm then back of the tensioner with a small flat head screwdriver you will have to hold it in the bolt it in and pull the driver out and you should hear it snap in place turn the engine over clock wise and recheck your marks to make sure you have it set wright.
hope this helps please leave feed back.
Oct 05, 2009 | 2000 Honda Hornet 250
What is the gap settings on a 2003 mazda protege?
usually around .045 some are around .060 if you look on the under hood engine labal is should specify which.
Aug 30, 2009 | 2003 Mazda Protege
I dont know what the telephone light means
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 14, 2009 | Belkin (F5D5231-4) Router
No power to cd player in car
Did you check the fuses on the car or on the stereo it self?
Jan 19, 2009 | JVC AM FM CD DET FACE CAR STEREO
HP DeskJet F380 All-In-One Printer Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
