Question about Water Heaters
REU-56ES Wont Fire Up I have
I have just purchased a Motor home fitted with a Rinnai REU-56ES,I have asked 2 egineers to have a look at it,and it has beaten them both.It appears to have 2 Black wires that are disconected from the Micro Switch on the right,looking face on.But one engineer said they were for an auxillary fan and nothing to do with my problem.So, I have 3 questions for you...1) Is there anyone local to me in the Romford Area who could fix it? 2) Can I still buy a new one,and just keep the current machine for spares?If so,Can you supply it and how much?3)If the model has since been up dated,is the new model the same size?And will it fit to the existing flue? I think thats more than 3 questions but Im now desperate. Thankyou in anticipation ****.
    Sergeant:
  • 276 Answers
On the fixya home page there is a column called repair service.just enter your proper zip code and the list of engineers of this product near to you will be shown with a proper profile and contact numbers.
Posted on Nov 21, 2008
  • Water Heaters Master
  • 19,396 Answers
If you are in Romford UK, then here you find a list of authorized repair:
Heating Services in the UK
I will see if I can find the service manual.
  • Ginko
    Ginko Nov 21, 2008
    I will answer more extensively to your questions:
    1:
    The best thing to do to find an authorized repair near you, is probably calling Rinnai UK at 01928 531870
    2 is not for sale anymore, if you buy a new model many spares will be different, you will still be able to use some common spare.
    3 REU-56ES is out of production, however you can still get the 58 e that is pretty similar for about 150 pounds, see :RINNAI 58E CARAVAN GAS WATER HEATER.
    Here is also the repair manual for your unit : Rinnai
    REU 56es
    Service Manual
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Nov 23, 2015 | Rinnai Digital Remote Water Heater Control...
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
I have a old Rinnai gas water heater Mod REU 55 FTB, after a year not in used, now the gas can not flow, how is the solution ? Thx
If it hasn't been in use for a year or so there could be a couple problems. Sometimes the gas dissipates from the line after an extended period of inactivity. You may need to try several times to light the pilot or the line may need to be purged. Also, if there's gas to the appliance and the pilot will light but not stay on the thermocouple is bad and should be replaced.
Feb 14, 2013 | Water Heaters
I have a rinnai 24 infinity model reu-242w-a. It ison the roof of a 3 storey townhouse we are moving into.Tthere are no remotes. It was working fine on demand until a plumber drained the system on the...
Ask the plumber who did the mods. to come a check that he hasn't crossed a hot/cold pipe. Really sounds like he has, this would cause hot water to mix with cold. Is the water hotter further away from where he did his work? This would be a clue. Easy way to check is to turn off the water to the hot water system, should be a valve on the middle pipe going in to the heater. This should turn off all water to all your hot taps. If you still have water at any hot tap or shower then the pipes have been crossed.
Mar 21, 2011 | Water Heaters
I have a Rinnai REU 55ft, which ignites but won't stay lit. We've cleaned the filters, fiddled with the dials and ensured that the batteries and propane are good. Any thoughts?
In these water heaters there is a part called a "flame sensor", if you can read the wiring diagram/schematic spend some time trying to find where it is at; it will be located directly in the burner compartment. It senses that the gas is lit and there is flame, if it does not then it will shut the gas off almost within 3 seconds.
Solution- Turn off the power to the unit completely and take the flame sensor out and clean it with a 000 steel wool pad. These flame sensors develop carbon from the gas and then stop reading properly. You can test the measurement if you had an electrical meter (uA is how it would be listed on your meter- most basic meters have this function).
Let me know if this works, if not I have another solution you could try (I'm pretty sure this will do the trick though) James
Jan 17, 2011 | Rinnai Water Heaters
Ignition problem: I have a gas hot water system: RINNAI CORPORATION; MODEL:REU-2008W-A the panel display temperature as 40C, when open the tap, the temperature display dropped to 12C, and no...
This is an error code 12, not 12 degrees. You have a short on your low voltage side by the sounds of it.. First disconnect the controllers inside the heater. Turn of the power first, 2 screws top and bottom to take the frnot panel off. Follow the low voltage wires (not the power point ones) to the PCB on the ride side and disconnect them both. Panel back on, power on and try the heater again. If this fixes it you have a short circuit in the controller or the wires leading to it. If not the most likely short circuit is on the thermal fuse which loops around the heat exchanger. This will need an expert, Perth has plenty north and south of the river. Give Rinnai a ring first, they have some good staff in Perth who might help.
Dec 02, 2010 | Rinnai Water Heaters
I need a service manual for a Rinnai Infinity 26 continuous flow hotwater system - REU-VR2626WG-AK Can you help me? Linda
I left Rinnai only about a year ago at a levle of State Service Manager. I had been asking for service manual for for many, many months. Basically as far as I am aware there is not a service manual for the WG. If you google Rinnai Infinity 26 manual you can get a PDF from the Rinnai NZ sales site but his dates baack to 2003. Unfortunately there are major changes to some of the components but it might be better than nothing. Just don't use part numbers, and you might find bits to check that now have voltage and resistance differences. Send a message to Rinnai complaining, I encouraged people to do so even when I worked for them!
Aug 26, 2010 | Water Heaters
Need to wire a zone control for a closed system with a circulator
thats because the rinnai does not have a set up for a circulating pump it would make the unit run all the time,, they are not designed to work that way,, you will have to just wait for the hot water to get to the faucet just like before,,don't let any one tell you there is a way once the water flows it turn on the tankless so it would never shut off, you could get on that goes on a timer on say the farthest fauset away from the unit and set the timer to come on like 2 min before you are ready to use the water in that bathroom in the morning or at night other then that there is nothing else you can do
Jan 28, 2009 | Rinnai Digital Remote Water Heater Control...
Water Heaters Logo
279 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
