Question about Husqvarna Chain Saw 20" Bar
Chain oiler replacement
I have a 025 stihl chainsaw and would like to replace the chain oiler myself. I can not find any spec on it to see if it is hard to do or not
  • Savu Mihai May 11, 2010
    is it Husqvarna or Stihl 025
  • 211 Answers
If it is Stihl 025 the chain oiler is on the bottom.First check if the worm gear(under the starter)is in good condition.Replace the starter(blocking the piston in the cilinder with a rope with many nods,that rope entering in the sparkplug hole).On the handle there are 4 screws on the right side (under 4 black plastic plugs,at the bottom 2 screws.)CUnlock them and take off the handle.At the bottom you can see the chain oiler( under the hose) the mark for right possition is there.Take off the oiler using a screw(lock clockwise into the oiler)and then pull it out.Clean with compressed air the oil hole.Put back together .Succes!
mihai71
Posted on Dec 01, 2008
How to stop a chainsaw beeping
Hi Wendy
You can stop using it :>)
You can take it to a garden equipment repair shop :>)
Or you can read the manual? What is the make and model?
I am thinking it is telling you the oiler needs filling?
Jun 14, 2016 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How does one replace the chain oiler in a 0009 Stihl chainsaw?
from stihl documentation it does not seem that you can replace it. I have appended the manual for you and an article dealing with chain oil delivery system for 0009
Stihl Chain Oiler Trouble
How to Unstop the Oiler on Stihl Chainsaw
http://www.stihlusa.com/stihl_ownersmanuals/009_manual.pdf
Jan 26, 2015 | Stihl Garden
How to adjust chainsaw oiler on stihl MS230
you cant. the oiler on an Ms230 is preset and non adjustable. Make sure the oil worm gear isnt damaged
Apr 13, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Ms 170 leaks bar chain oil out bottom, no oil on chain
Your clutch drum bearing has gone bad, letting the clutch drum to move around and cut into the oiler behind it, so now it just pumps the oil out that hole. You have to get that fixed to use the saw, otherwise you're going to cause catastrophic damage to the saw very soon.
Sep 25, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Have a stihl MS180 and it is not pumping any oil out of the hole and slot that makes contact with the bar. How do you remove the oil pump?
To remove the oil pump you need the following:
Assembly tool 1123 890 2200 Removing oil pump Puller 1130 893 1400 Installer 1130 893 1500
I would recommend trying to clean out the oiler first.
Please comment on this and tell us what type of oil you were using. There are rumors of wrong oil clogging or wearing the oilers. Was it used motor oil? Thanks Joe
Feb 16, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How to replace oil pump in Stihl 018 chainsaw.
The oiler is set in place to a depth premeasured and tough to duplicate without the proper tool. If you use a proper sized bolt 5mm about 200mm long. After threading in till it stops mark the depth with a marker. pull the bolt out and the oiler will be on the end of the bolt.
thread the new oiler on and reverse the procedure.
My recommendation is to see a local service dealer like www.arcolawn.com and purchase the speciality tools:
21 Assembly tool 1123 890 2200 Removing oil pump
22 - Puller 1130 893 1400
23 - Installer 1130 893 1500
After saying all that I would tell you that a dull chain is the number one cause of "oiler problems" because a dull chain will over heat and make it seem as if the chain has no oil.
Good luck
Joe
vote this up if it helped.
Jan 01, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How do I replace the oil pump on a Stihl MS170 chainsaw
The oil pump is pressed in from the bottom. There is a special bolt and bracket to make sure the pump is set to the right depth. Your local dealer should bea able to get the tool for you but it will be cheaper to have the shop do the work.
PS it is more common on this saw to have a dull chain act like it is not getting enough oil than to have a bad oiler.
I am gold certified and have been doing repairs since before the ms series. I have only replaced two oilers in that time.
Good luck
JOE
www.arcolawn.com
Dec 16, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I have a Stihl 16" 012 AVT chainsaw. I cannot get
First thing I would try is wash out the oil tank with a little bit of diesel fuel then run some thinner oil thru it to see if it gets better . I usually leave bar and chain off when I do this.. or if it is oiling but not going down the bar check the bar oil holes.
May 10, 2017 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
May 09, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Husqvarna Chain Saw 20" Bar Logo
1,252 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
