Question about Avanti DG241BS Stainless Steel Gas Kitchen Range
Lighting the oven
Have had the range for over a year--recently, if the oven is not lit just right, the burner goes out. sometimes it will light on the second try, and sometims it won't light again. also with the oven burner, if you use the oven once during the day or evening, then shut it off, then try to light it again later (even an hour or two later), it won't light again. so is something wrong with our unit? or is there some kind of safety or emergency shut off that happens automatically? this is a big problem if you can't use the oven more than once per day, or if you have to just keep it on if you want to use it more than once in a day (i.e., making dinner and baking cookies in the same evening). please advise!
  • nice try May 02, 2009
    We have a 24-inch Avanti range -- and the oven will not stay lit. This stove/oven is a piece of caca.
I have similar problems with several 20-inch Avanti ranges. Solution(s); Get a new range, different brand. Cool the range between lightings.
Posted on Oct 09, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
I have an arr3140ss American gas range. Just recently installed new burner and igniter.Roasted and baked all last week no problem todayI turned on the overn abd got up to 550 for pizza. put pizza in
Sometimes the pilot light goes out on this type of oven. This could be caused by a draft, or sudden jolt. Even if the top burner is working, the bottom won't go on until the pilot is lit. Check your manufacturers' instructions for locating and re-lighting the pilot.
Best of luck.
Nov 30, 2014 | Kitchen Ranges
I have a whirlpool GW395 gas stove with a problem. When you first turn it on it lights, it will stay lit for about 45 seconds then the burner will go off , after you let it set for about 45 seconds it...
The usual problem with these ovens is the oven burner itself. the burner will click 3 times and usually lights but after a few minutes shuts down and will no light again until you reset the control. If this is happening then try replacing the oven burner. It comes as one unit the burner assembly and electrode. Part # 8191123. If this doesn't work then it coould be your spark module unit. This is about twice the cost or more.
Dec 01, 2012 | Whirlpool GW395 Gas Kitchen Range
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Dec 07, 2008 | GE Kitchen Ranges
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
36 inch range gas not flowing to both burners
I am having the same problem with my oven. One burner comes lights on just one side. Then the second one comes on. Just one side. After a while both side get lit. My concern is unburnt fuel coming out of the oven. Going to trying taking the burner out and cleaning the ports
Sep 18, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Open Questions:
Avanti DG241BS Stainless Steel Gas Kitchen Range Logo
618 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
Lawrence Oravetz
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
