Question about Samsung SyncMaster 930BF 19" LCD Monitor
Semi-second image when turned on..then black screen
Everytime i turn on our syncmaster 930 bf it gives an image for about half a second, after that blackness.
tried rebooting.switching pc's and cables and turning our screen on an off for a number of times...same result every time.
  • 1 more comment
  • theresia0 Nov 22, 2008
    I have a black screen and only the green light is flashing approx. everey 1.5 second.
    Ruud
    no respons on buttons etc.
    Only the little green light s flashing slowly every 1.2 (approx) second
    Is this screen after a kind of reset usable again. It is only 3 years old....
  • lassebrown Dec 23, 2008
    i have the same problem, only the green light is showing but dissappearing every half secound and im affraid that he is over the rainbow.
    i would repair him if it makes any sense cous i love this little fella we had some fun times together. please help!!!!!!!!!!!!!!!!
I have the same problem
Posted on Jan 28, 2009
Samsung syncmaster 245b lights up and then turns black...
more than likely your video card has gone bad .. try to get a new video card and install it or take computer to your computer shop and have them replace it for you
May 17, 2017 | Samsung SyncMaster 245BW Monitor
Samsung syncmaster 172v Screen goes black after about one second. Comes back to normal after turned off, but goes black again in about one second. Rebooting computer has not fixed this.
Sorry it is like your monitor needs service. Electrolytic condensators in power supply need to be changed. Give it to an electronic shop, it is a job for a specialist.
Oct 18, 2010 | Samsung SyncMaster...
Image does not fit screen
Set your setting to "Secondary Screen Only"
As your setting for both screen doesn't seems to be adjusted but you can try turn it off.
Jul 26, 2017 | Samsung SyncMaster 172N 17" LCD Monitor
Monitor syncmaster samsung 940 BF becomes black after a few sec.
Try to boot the system with safe mode and check whether you are getting display. if yes, need to download latest driver for display card. if No, then check the monitor cable was properly connected or monitor may faulty. Replace/repair the same will solve your problem.
Also check the DPI and resolution configured in display properties.
Revert back for more clarifications or assistance required.
Dec 12, 2009 | Computers & Internet
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
Aug 29, 2009 | Samsung SyncMaster 932B LCD Monitor
My monitor is a SyncMaster 2220WM... the othe day
Your INVERTER has crapped out. Look on ebay.
Jun 26, 2009 | Computers & Internet
Monitor will not turn on and the green light just flashes
There's an internal hardware electronic part/s of your samsung syncmaster 930 that is cold soldered / defective. I suggest to bring the unit to an authorized service center to fix the problem. regards
May 29, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Syncmaster 910t blinks image perfectly once and goes back to black
I found a site that sells your (our) part: samsungparts.co. Look up that model number for the power supply under "Part #" and it seems to run about $60-70. I'm probably going to order one and give it a shot as a drop in replacement.
Oct 18, 2008 | Samsung SyncMaster 910T 19" LCD Monitor
Syncmaster 226bw goes black
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Jun 23, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 930BF 19" LCD Monitor Logo
472 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
