Question about ASUS P4PE2-X Motherboard
Pci slots when i attached a modem to pci slots on p4pe2-x mainboard it does not see the driver and so that it does not work
    President:
  • 2,992 Answers
The drivers are supplied with the modem when you buy it. If you didn't buy the modem new or lost the driver disc, you can usually find drivers online. Try a Google search for "xxxxxx drivers" (replace the xxxxxx with your modem model number) and you should find lots of places to download them. Or provide the model number here and we'll see what we can find.
Posted on Nov 21, 2008
533 sound driver
The 533 you list is the Front Side Bus (FSB) speed and has nothing to do with the sound driver. The model # P4I45GV returns two possibilities - a REV 3.0 and a REV 5.0. Look at the mainboard. The REV 3.0 has only 2 PCI slots, while the 5.0 has an AGP slot and 3 PCI slots. The audio is a C-Media Chipset. Both versions use the same audio driver. You can access it here:
Audio Driver Link
Dec 11, 2013 | Asrock P4I45GV...
On fixing 56 kbps Tech-Com fax modem on PCI slot of Asus P5KPL-AM/PS board System is not booting . But after removing the Fax card , I am able to boot the system. Can you suggest solution please ?
Hello the homepage is here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=22&m=P5KPL-AM/PS&os=17&hashedid=y014Wy067iZxxPeP
Please select your windows system.
Click on global for download.
Upgrade any missing drivers for the mainboard.
The files needs to be unziped before you install it.
But you need the driver for the modem aswell.
Try finding the driver here:
http://www.multitech.com/en_US/SUPPORT/Updates/Software/
By selecting the modem model.
The modem card could have a defect or not supporting your windows system.
Buy a new (faster) fax card.
Good luck
Nov 25, 2012 | Computers & Internet
Does XFX radeon 7770 work on MCP73PV
Hello you can easy install the graphic card.
It should be printet in on the mainboard what socket it is.
There is 2 different ones: AGP and PCI-E slot
I think you have an PCI-E slot.
All newer mainboard have pci-e slot.
An AGP socket card does not fit:
If you are unfamiliar with mounting a graphic card
Let a expert do the job.
It does not cost much.
Make also sure you have the driver for it.
Good luck
Oct 29, 2012 | Computers & Internet
Driver pci slot
PCI slots do not have drivers. Only the cards that are in them do. If you mean mainboard or chipset drivers try "Driverpack solutions" it is free and very good.
Jul 10, 2012 | Soltek EQ3401A Barebone
I want to install a graphic card that is better than the onboard one
Hello there, I am the Expert that will be helping you today, my name in damnor01.
Welcome to Fixya.
You need to start by identifying the slots that are present on your computer mainboard.
PCI is the white slot
PCI-Express is the faster than PCI. PCI-Express usually has a clip on the rear of the slot.
Use PCI-Express if you can.
Basically find the model number of your computer mainbard and then find the specs of your mainboard using google. Model number is printed on the board, between the PCI, AGP or PCI-Express slots or between the RAM slots.
Then purchase a card that is supported by your mainboard and install.
damnor01
Feb 06, 2011 | Acer Computers & Internet
How could we know the right model to download the right audio driver in your PC
You need the model number of you computer mainboard, if you are using onboard audio and if you are using a sound card you would need the model number of that card. The model number of the mainboard can be found, either between the PCI, PCI-Express, AGP slots or near the RAM slots.
So it's the name of the manufacturer of your computer mainboard, eg: Asus, MSI, Gigabyte, Abit, Foxcon etc... and the number that follows.
Then go to the manufacturers website and under the support heading, find your mainboard audio drivers.
damnor01
Dec 19, 2010 | Computers & Internet
PCI slot no working
Hi Adam, you did a great job trouble shooting your system & you even answered your own question. If one PCI slot works the other should but since you tested that you're self & the PCI slot failed than the PCI slot is bad. My guess is one or more soldered points under the PCI slot. (Underside of the motherboard) is cracked or broken. It may be possible for you to re-solder the cracked or broken joints. The only way to prove this theory will be to remove the entire motherboard from the case & visually check every single joint. There is no single driver for the PCI slot. The PCI slots are part of the chipset driver which is already installed. There is alway replacing the motherboard.
Great job Adam!
Mike
Aug 12, 2008 | MSI K9VGM-V Motherboard
DMI pool search and system hangs
hi there check that the pci slot is nice and clean then make sure the card is inserted fully, and restart your machine, if the problem still persists try and get the most up to date driver for the card from belkin's website copy following link and paste in your address box http://modem.free-driver-download.com/D-Link/14620/D-link-DFM-562IS-Modem-Driver-Windows-XP.html and install it restart the computer if the problem is still there it's 100% faulty modem card and it needs replacing. hope this helps. regards
Jun 21, 2007 | D-Link DFM 562IS (DFM-562IS) Modem
Problem with installation of Chaintech FX5200 P-FX20 256MB PCI
You got the names wrong, there is no PCI version of the FX5200, therefore it is AGP or PCI Express only.(doubt the later) Now asuming you havent forced the card into the wrong slot, take the modem out. Check in the BIOS at bootup if the machine has an onboard graphics card, disable that or set to boot the AGP or PCIXpress. Then manual IRQ settings. Set those to AUTO. There is a rule to PCI cards (really doubt yours is) to ALWAYS put a graphics card into the 1st PCI port on the board, most boards have labels, manual has it for sure. It will aslo say if and which pci port shares its IRQ (interrupt request) with what device on the mainboard - that conflict causes some strange things to happen later in windows... Then boot to safe mode. If it boots, check device manager for duplicate devices. delete every duplicate and reboot. Most likely it is just windows going nutz, unless there was some PCI / AGP, force insertion magic or you forgot to unplugg the power cord and the mainboard was live and had suffered some damage while changing the cards... More details would help, hope this will be of any use m8. Good luck!
Jan 10, 2007 | Chaintech GeForce FX5200, PCI Graphic Card
ASUS P4PE2-X Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
