Question about Canon Rebel XT / EOS 350D Digital Camera
Canon 10d digital camera Err 02 message - CF card error Have tried multiple CF cards in this camera with same result. Cards all work fine in my other 10d and in card readers / media players. Checked CF card slot - no bent pins. any ideas?
  • 477 Answers
Most likey your problem is the cf card reader when ever the camera was made they could have not heated up the board all the way causing a cold solderjoint after time this joint becomes week and gets disconnected on the back side no visual damage is seen causing you the error you are getting. best thing to do is take it to a repair shop and have them fix it or the manufacture should repair it for free because there is no fisical damage.
Posted on Jan 16, 2009
Canon 20D. Says "Err
Error 99 is a result of an electronic communication problem normally between the lens and the camera body.
Use a red pencil eraser to "polish" the contacts even if they look clean do it again.
Take care to keep dirt out of the camera and lens bodies.
Another thing is often times the camera firmware needs to be updated to move on from this.
Another thing is the CF cards? The 20D was in an era where pretty well the larges CF card was a 2gig,I use several 1gig however if you have updated your cards to say an 8gig the firmware just can't handle the card.
Okay moving on clean the lens and body, update firmware, make sure the CF card isn't beyond the camera capabilities and last if all that stuff didn't work the it's possible the actual sensor is really dirty and needs cleaning.
The worst case scenario is that the shutter has failed. The Canon 20D is only good for 60,000 actuation's.
Hope this give you a few options
Apr 29, 2011 | Canon EOS-20D Body only Digital Camera
Canon rebel xt eos shows ERR CF. What do I do now?I tried a new flash card but still got the same error message. When I try to preview pictures I have already taken the screen says ¨no image¨. My...
Check that the pins in the camera that connect to the CF card are clean and not bent. You will probably need a good light and a magnifying glass to see into the card slot. If you can see a pin that is bent you could try straigtening it. BEWARE- turn off camera and use a non conducting "stick" ie cocktail or toothpick. Not sure for a Canon but a colleague paid £40 for a new pin assembly for a Nikon with similar problem.
Hope this helps.
Steve A.
May 06, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel xt does not accept CF cards for no apparent reason
It sounds like a bent pin in the CF slot. This is not a do it yourself fix. Take it to a repair shop.
Jun 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Have canon 350d, yesterday came up with CF err. Tried 2 diffrent cards, same thing. Friend tried my CF cards worked fine in her camera. Please help
Please look inside your cardholder and you have seen a lot of small pins.
If one or more of the pins are bending or missing it gives an error on the camera display
regards Rob NL
Apr 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Feb 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Rebel XT will not work with new faster CF cards.
Check the volume and speed of memcard, maybe it is not compatible. error 99 is an indication that a lens or shutter curtain is not working, so i cant see any connection with the memcard problem. Check your camera memcard compatibility.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
4. Insert a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
Error 99
I get error 99 sometimes on my 20 D but it?s usually to do with a lens that is attached. Sigma lens have been known to cause error's. If it's not that or dirty contact on the lens then it could be a more serious problem. I would at least check it out with a canon dealer/repair centre.
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
610 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
