My tv doesn't want to turn on, the green light on the power button comes on for a few secnods but the tv won't turn off, then the green light turns off, and then it comes on again two more times with any results
    Genius:
  • 2,920 Answers
Id take it to a shop and have it repaired i dont think it will cost much more than 100.00 to get it fixed
Posted on Nov 21, 2008
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
The TV won't turn on. The little light by the power button doesn't even come on
Blown fuse caused by a shorted power supply. Relacing the power supply board should solve the issue in most cases. You can get a power supply board from www.tvrepairworld.com
Oct 27, 2012 | Polaroid LCD-1700 17 in. Television
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Tv has been turning off right after you turn it on then after a few attempts it would stay on now the power button on front turns green, it tries to come on but then turns off.
Sounds like high voltage power supply has gone bad. You can try purchasing new PS online and replacing yourself if handy or you will need to bring in for service.
Mar 04, 2011 | RCA HD52W59 HDTV Projection Television
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
