Question about StorCase S35F102 120 GB Hard Drive
My Mac won't recognize my external hd
I was wondering if someone could help me figure out why my Mac G4 won't recogonize my RhinoJr. firewire 800. I unplugged everything the other day to work on my laptop then when I went to plug it back in the external HD won't show up on my desktop. I can't seem to figure out why this is. Could someone please help. I have shut everything down and unplugged everything then plugged it back in and turned it on and nothing seems to show up. thanks in advance for the help. Derek
0 characters
1 Points
My Maxtor 200GB external HD is not showing up on my Mac G4. I've tried USB & Firewire connections. Restarted the Maxtor then computer. Restarted computer, then Maxtor No good. Thanks for your...
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 26, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
My mac G4 not recognize my 500GB external FantomDrive. HD light is on but Mac can't see it!
If you bought it from a friend, then ask them to reformat it for you as a FAT32 partition. Mac can not see NTFS, which most Windows users use since you get more space on the drive.
If it is brand new and your G4 isn't recognizing it, then I would return it for a new one. I don't trust things that aren't working out of the box, especially when they charge so much for things.
Dec 16, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Freezes up During Backups
I suggest an application called "Disk Warrior" it has always maintained high ratings among us Mac enthusiasts it has a hardware test function built into it and seems to be a little better at verify and repair functions than Disk Utilities which you can try also if you haven't yet. You may also consider trying a different firewire cable if you have one handy. Other than that a reformat should have put the disk back into an original state however the disk could have been damaged by not un-mounting it in rare mac cases. If you have the time you can also reformat the disk again although I would try the first two options first.
Apr 23, 2009 | Hard Drives
Vista (32) will not recognize my lacie d2 external harddisk
solved: after referring to the userguide, I found that I formated my drive with a OS format, which can not be recognized by VISTA >> formated to FAT32 and now it works...
Jan 03, 2009 | LaCie d2 Extreme 250GB External with...
HD does not apppear on desktop
I would disconnect it and connect it again.You probably will be asked to assign it a drive name like G-Drive or E-Drive.
Jan 01, 2009 | Western Digital WDG1C2500N MyBook Premium...
My powerbook g4 won't recognize my external hd or my web cam but it recognizes my ipod.
I am not really sure but i think the Camara and the External Hard Drive have to be compatible with Apple I think so you can use it. An IPOD is made by Apple so thats why your G4 recognizes it. I would just buy like a USB Drive. And also try to download the Drivers also and you can do that by google-ing it that sort of think. Anyways just use a windows based computer Bro its much more efficient. Let me know how it goes alright.
Oct 02, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
May 29, 2008 | LaCie (300728U) 250 GB Hard Drive
Computer OS earlier than stated
May 21, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
StorCase S35F102 120 GB Hard Drive Logo
20 people viewed this question
Top StorCase Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a StorCase Hard Drive Expert? Answer questions, earn points and help others
