Monitor keeps going black - Computers & Internet
  • 1 more comment
  • sghynes Nov 21, 2008
    the monitor will work for 5 hrs when it is disconnected from the computer for a number of days after a certain amount of time with it running it will go black sometimes it will flicker but doesn't come on so it can be used. Any help would be great at this tiime. Thanks
    Thanks for the info. Kinda thought it was something to do with the inside of the monitor. You have been a great help. Thanks again
  • David Preston
    David Preston May 11, 2010
    Could you please explain your problem a bit more thoroughly? Does it go black immediately? Does it happen after a certain Length of time?
    Any other symptoms?
  • 207 Answers
Well I was hoping it was going to be the simple answer of the "Energy star" settings kicking in and I would walk you through changing those settings.
This however sounds more like a conductor in the power supply/transformer has a break in it. When its cold (not powered up) its expanded and able to connect with the rest of the wire. Once its powered up the electricity going through it causes it to contract and seperate.
Unfortunately this is a HIGH Voltage device and I would not recommend a self fix to someone who is not experienced with HV electronics for this type of device. As a mistake could be fatal.
That being said, if you think you have the necessary experience, then you'll want to find out the part number for the power control board for this unit and get a price for it. (Sometimes these "Components" when purchased individually can cost more than a new monitor) If you can get the part cost effectively then it is a matter of swapping out the boards.
If you are NOT comfortable with HV then find a service shop that will give you a free estimate. If that estimate is cheaper than a new monitor then get it serviced. Otherwise It may be more cost effective to get a new Monitor (Plus you'll get a warranty with it)
I hope this helps you,
Sorry I couldn't be of more help.
Posted on Nov 21, 2008
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
The monitor keep going to black when its still on.
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but black screen, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 10, 2010 | Dell E228WFP LCD Monitor
My emprax monitor keeps going black. why is this and what can it?
You can have failed filter caps in the power supply, or failed backlight inverter, or worstcase will be the lamps, open it up and inspect the caps first and report back what you find so we can guide you further, see example of failed monitors:
Jan 24, 2010 | Emprex LM1704 17" Monitor
Screen keeps going black
check your numlock key presss it then check numlock led if it on /off then your computer gives dispaly to monitor perfact then when you power up ther computer press F8 key then enter in enable vga mode if you see safe mode and other mennu.
But if you can't able to see those menu then you have to check your monitor to cpu vga cable connection.
Also check your monitor is properly working? or not.
Aug 13, 2009 | Acer X193W LCD Monitor
Monitor keep going to black screen while viewing.
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
Apr 22, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Check video cable keeps reading and go off, but the power is still on
the screen on most monitors will go black if the cable connecting them to a device is lose or disconnected altogether. try the cables in the back the ones other then power cable
Apr 15, 2009 | Neovo F 415 (Black) 15" LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
Mar 08, 2009 | Computers & Internet
bad capacitors you will need to replace the "blown caps" and resolder new ones in.
Feb 01, 2009 | Star Logic 17" LCD Monitor
Monitor problem
This monitor is bad replacement is the only option as the CRT monitors are obselete you could get a good deal on one if you are not shopping for a flat panel!
Oct 24, 2007 | Samsung 793S 17" CRT Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
