Question about Dell Computers & Internet
Restoring dimension 9150
I am unable to restore computer to original factory restore.( Windows XP Media 2005) When I press Ctrl-F11 it starts the restore process - warning about are you sure comes up and when I select restore a Ghost image appears briefly and then a message about unable to complete restore comes up. When I restart system it shows ''Loading PBR for descriptor 2 ... Done'' and it freezez there
I even tried booting from a Windows XP cd to install a fresh copy but after the initial screens when you select install it says no drives found. I tried a new 250GB drive but same results. The drives are SATA. The drives are recognized in bios and with the original drive when I boot to diagnostics partition everything pases including drives ram etc I believe its something to do with SATA and XP but don't know how to fix please help as I've been at this for 12 days
  • Anonymous Dec 23, 2008
    Link posted as solution does not contain the correct files needed.
  • evrclr6009 Dec 28, 2008
    i dont have a floppy drive, what do I do?
    Sergeant:
  • 207 Answers
Yvon,
It sounds as if your restore partition has become corrupted. You vcan Contact Dell and order a restore disk
As far as trying to Install from Install CD goes. Well Win XP does NOT recognize SATA drives natively. You have to install the sata drivers to get them to appear. You can download them from the link below.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=XPS/DIMENSION%20400/9150&os=WW1&osl=en&catid=&impid=
If you have a floppy drive, this is easy just copy to a floppy. Then during the install WinXP says something to the effect of "Press F6 to install 3rd party or RAID drivers" hit <F6> and direct it to the drivers on the floppy.
You should now be able to complete your WinXP install.
If you don't have a floppy drive post back here and we'll try to see if we can get the drivers in there another way.
Thanks
Dave
Posted on Nov 21, 2008
Factory restore
Dell Dimension computers have a built-in PC restore system that allows you to quickly restore the PC to its original factory settings.
The PC restore is located in a hidden partition of the PC's hard drive and contains a copy of the computer's original factory installed software.
There are two different ways to restore the Dimension's settings depending on which operating system your computer is running.
Windows XP
Disconnect all peripheral equipment that is attached to your computer such as printer, scanner, external hard drive and memory sticks.
Restart the computer.
After the Dell screen appears on the monitor, hold down the "Ctrl" key and press the "F11" key.
If the Windows XP screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
Highlight "Restore" in the Dell PC Restore window by using the tab button.
Hit "Enter."
Highlight "Confirm" in the restore warning box by using the tab button.
Hit "Enter."
This will start the system restore process.
Do not attempt to turn off the computer during this process or vital system files may be damages and you will not be able to restart your computer.
Click "Finish" in the box that notifies you that the restoration has been successful.
Hit "Enter" to restart the computer.
The computer has been restored to the original factory settings.
Windows Vista
After the Dell screen appears on the monitor, press the "F8" key.
If the Windows Vista screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
Highlight "Repair Your Computer" by using the down arrow key in the Advanced Boot window.
Hit the "Enter" key.
Click "Next" after selecting a language. Log into the computer as an administrator.
"OK." Choose "Dell Factory Restore."
Click "Next."
Check "Yes" next to the reformat the hard drive and restore factory settings option.
Click "Next" to start the restoration process.
The computer will automatically restart itself to its original factory settings.
Aug 18, 2013 | Dell Dimension C521 PC Desktop
Hello, i have a dell xps m1210 laptop. i was using my computer and when i want to restore to factory settings i was using ctrl f11 combination and restoring back. but i now installed windows 7 on c drive....
No the hidden partions rely on the main partion to have some files still intact to complete a repair of the operating sytem then restores the files back to thair factory settings, to put xp back on you will need the factory recovery cd or dvd. If you buy a copy of xp and install it then ust eht recovery it should restore it to factory with drivers as well.
Jul 01, 2011 | Dell XPS M1210 Notebook
How do I restore to factory settings with out disk
back up you computer then reboot. While it's booting up, press and hold "Ctrl" + "F11" This should bring you to a factory restore utility.
Jan 15, 2011 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I want to restore my dell dimension 9150 to factory settings can u help
If you were using Windows Xp just press Ctrl + F11 when you turn on your computer.
Press F8 if you were using Windows Vista then select repair your computer from the list.
Then if you have any disk or any Operating System disk insert the disk then boot from CD and follow the on screen instructions.
Hope it helps you....:)
Sep 06, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
How can i restore my dell dimension to factory setting
to restore the settings you have to follow the steps
Instructions
    Windows XP
  1. Step 1 Disconnect all peripheral equipment that is attached to your computer such as printer, scanner, external hard drive and memory sticks.
  2. Step 2 Restart the computer. After the Dell screen appears on the monitor, hold down the "Ctrl" key and press the "F11" key. If the Windows XPmag-glass_10x10.gif screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
  3. Step 3 Highlight "Restore" in the Dell PC Restore window by using the tab button. Hit "Enter."
  4. Step 4 Highlight "Confirm" in the restore warning box by using the tab button. Hit "Enter." This will start the system restore process. Do not attempt to turn off the computer during this process or vital system files may be damages and you will not be able to restart your computer.
  5. Step 5 Click "Finish" in the box that notifies you that the restoration has been successful.
  6. Step 6 Hit "Enter" to restart the computer. The computer has been restored to the original factory settings.
  7. Windows Vista
  8. Step 1 Disconnect all peripheral equipment that is attached to your computer such as printer, scanner, external hard drive and memory sticks.
  9. Step 2 Restart the computer. After the Dell screen appears on the monitor, press the "F8" key. If the Windows Vistamag-glass_10x10.gif screen appears before you can finish this step, wait for the computer to finish rebooting and restart the computer again.
  10. Step 3 Highlight "Repair Your Computer" by using the down arrow key in the Advanced Boot window. Hit the "Enter" key.
  11. Step 4 Click "Next" after selecting a language. Log into the computer as an administrator. Click "OK." Choose "Dell Factory Restore." Click "Next."
  12. Step 5 Check "Yes" next to the reformat the hard drive and restore factory settings option. Click "Next" to start the restoration process. Do not attempt to turn off the computer during this process or vital system files may be damages and you will not be able to restart your computer.
  13. Step 6 Click "Finish" in the box that notifies you that the restoration has been successful. The computer will automatically restart itself to its original factory settings.
thanks
May 18, 2010 | Computers & Internet
How do reset my compuer to factory without a cd
All versions of windows have whats called system restore.
Hopefully it was turned on.
Go to start button, all programs, accessories, system tools,
system restore, click on choose a different restore and then next,
now, on the next page click on the little box that says-show me all restore points, now pick the oldest restore point, and this will return the pc to
a state when it was new.
Feb 07, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I want to factory restore my dell dimensions 3000.
There are three methods available.
1) Use Windows XP System Restore.
If you cannot access Windows XP, the following two methods are available.
2) Use the Dell Operating System CD, and the Dell Resource CD.
If you do not have these restoration CD's,
3) Use Dell Restore by Symantec
With this method all personal files you have, and any programs, or applications you have installed, or downloaded, will be GONE.
(Personal Files: My Pictures, My Music, My Videos, and personal files you have created)
Turn the computer on. AS SOON as you see -
www.dell.com, appear in the blue bar, Press -
the CTRL key, AND the F11 key -
AT THE SAME TIME. (Not shouting)
If you do not press both keys at the same time, and in time, let the computer load. It may stop at a blank screen, with a blinking cursor.
It's okay. Now press the CTRL key, ALT key, and DELete key at the same time.
This will restart your computer. Try again when you see the www.dell.com logo.
If upon pressing the CTRL key, and F11 key, you go to the next screen, left-click on - Restore
On the next screen click on - Confirm
Takes about 6 to 10 minutes.
After the restoration has stopped, click on Finish.
Your computer will now reboot.
Should you need help with Windows XP System Restore, or using your Dell restoration disks, please state so in a comment.
Jan 31, 2010 | Dell Dimension 3000 PC Desktop
Hello. I want to restore my Dell Dimension 4300 to original factory settings
press the 'ctrl' and F11 when the blue bar w/the dell.com appears. Inside the Dell PC Restore Partition Dell has supplied the user with a backup image made at the factory, and this backup is stored in the DSR partition. It is this backup that is restored from when the Ctrl+F11 keys are pressed.
Jan 01, 2010 | Computers & Internet
Basically, everytime I try to log into windows I am logged straight back out. I know there is a dodgy registry entry that needs changing... but how can I access it? =S
hey buddy if u want to restore all u need to do is a Dell pc restore.this step will restore ur system to factory Setting.to do a restore press the ctrl key Down and Tab the F11 key on the Bios page u will be take to the Dell pc restore.Cautious All DATA will be Lost icluding Virus).
May 16, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Computers & Internet Logo
1,775 people viewed this question
Alun Cox
