Question about Kenmore 24 in. 16534 Built-in Dishwasher
Extended Cycle and No Dry
My dishwasher is about 4 years old and is a replacement of one that blew an element within the first six minths under warranty. What starts as a 78 minute cycle on smart wash lasts upwards of 2 hours while it is heat-pausing. (I keep my water heater turned up quite high -- which offsets any savings I'm getting from this energy-saving dishwasher! ) As well, the heat dry is ineffective and unless I open the door immediately and allow the dishes to air dry, they are still dripping when the cycle is complete. I'm guessing either an element or thermostat. I'm pretty handy - - can I replace either myself and how do I go about finding out which one? Has anyone else had problems with this model? My aunt has one and has exactly the same problems.
  • Penny Stinson Jan 04, 2007
    Thanks, this makes sense. My unit starts with FP21 (but Canadian numbers don't always jibe with US) but this sounds right. Will check out as soon as I can and report back.
    Thanks again.
    Pennys
  • mlsnts Feb 06, 2009
    My element also went bad. I am trying to find a diagram of how to replace it. Any idea where I can get one?
    President:
  • 878 Answers
Pennys, If your serial number begins with FM27 through FM33, there was a service flash regarding the heating element not heating the water enough. If you can use a meter, you can ohm out the element. It should read between 10 and 35 ohms. The recomended part number for the replacement is 8572861 for plastic tub and 8194200 for stainless. If you remove the bottom toe panel there should be a tech sheet attached. Here you will find the procedure for using the test mode to test other componets of the dishwasher. To answer your last question, there has been many problems with this issue on this dishwasher. Catriver...post back.
Posted on Jan 04, 2007
I broke down and called in a service tech. Yes, the element was shot but once replaced, the thing works like it was supposed to! Unfortunately the cost makes you appreciate why people are now replacing rather than repairing.
Posted on Jan 25, 2007
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Starting the dishwashing cycle, extreme loud noise when dishwasher starts pumping water. Loud noise stays during pumping cycle. Dishes are clean and dry and no water in tub when cycle finishes.
If your unit is a Kenmore or Whirlpool (there are several other brands that use many of the same parts) and is less than 6 years old then it may pay to first check and clean out the chopper assembly for hard debris. If that doesn't do it then you may want to consider replacing the motor and circulation pump as a complete unit for between $160 and $200. Not too difficult a task for a moderately handy guy with some tools. Maybe 2 hrs. The bearing itself is not serviceable I understand, and would be considerably more difficult. Over six years old then you can buy a great quality machine for about $500.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Oct 23, 2013 | Kenmore Dishwashers
Dishes are not dry anymore after cycle?
Hello there:
If` you ahve already checked all of the filters and they are ok than your drying cycle has problems to check these check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat. there:
Normally if you have just started to have this problem and you have checked all of the filters and are sure they are ok than
Jul 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
MAYTAG DISHWASHER DOE NOT DRY DISHES AT THE END OF CYCLE. I SEE A HOLE IN THE HEATING ELEMENT. THE DISHWASHER IS ONLY 2 AND ONE HALF YEARS OLD.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47136&diagram_id=676851#d676851
this link will being you to a picture of your prt
this is a very easy reapir
take off the toe kick
look right in front you will see the heater wires and lock nuts
loosesn those and pull the heater staring up
replace the element
and reconnect
Oct 27, 2009 | Maytag MDB9100A Dishwasher
Kenmore Elite 665 16912001 Dishes not completely dry.
you can check for the elemant open. it will have to be pulled out.the connection may be bad to the heater.
Oct 30, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Indesit DI620UK Dishwasher fault
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Jul 19, 2008 | Dishwashers
Wet dishes
Heating element
Drying fan
Thermostat
Jul 19, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Light flashing
There was a problem with the heating cycle , the seven flashes indicates the temp never reached the setting. You can try running a service cycle that will reset the control, then try running a normal cycle if it stops agin will have to find the part causing the trouble believe they actually came out with a revised heating element on this. to run service cycle press heated dry , normal, heated dry, normal within six sec then the d/w should step through a service cycle.
Jan 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 24 in. 16534 Built-in Dishwasher Logo
139 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
