Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher dispencer will not close
The spring is ok. it is 6 years old. used every day. has been getting worse and worse for 1 month.
  • sandylewj Nov 25, 2008
    beko dishwasher door is heavy and wont close
    Scholar:
  • 61 Answers
Sounds like the actual dispencer mechanisum is worn or faulty either the latch or the catch you can usualy buy the whole unit to replace this, all this does is keeps the tablet in during the initial pre wash then adds the tablet during the wash after 5 mins open the door and drop the tablet in it will still work the same and save cost
Posted on Nov 21, 2008
My Bosch is only a few months old and it won't drain the water.The filter is fine. It's a shea43p16uc60.
Your bosch washer should still be under warranty:
  • Limited warranty, entire appliance, parts and labor (1 year)
  • Limited warranty for non-electronic components; parts only (1st to 2nd year)
  • Limited warranty for control board (microprocessor); parts only (1st to 2nd year)
  • Limited warranty for motor or any component of the motor (1st year to 10th year)
May 19, 2011 | Bosch SHE43P16UC Builtin Dishwasher
My LG dishwasher is about 1 1/2 years old. My problem is that the detergent is no longer being dispenced properly. Much of it remains in the dispencer after use. What can I do about this?
open the dispenser while the machine is in operation and pour some extra water.
this will make the detergent to flow more inside the machine fully
Sep 16, 2008 | Dishwashers
Bosch SHX43C05UC Dishwasher Problem
Any error messages on Screen or anything else fishy..?
Apr 08, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Have a Bosch dishwasher, about 10 years old works ...
Check the hinges in the sides. may be requires little lubrication. Use an appropriate lube spray available in your shopping area.
May 21, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I have a BOSCH model 53L06UC dishwasher and was
every bosch dishwasher unit is different. you can get odor from different source. #1 solution to fight odor is the proper maintenance. every month run the cycle with just a cup of vinegar on a hot wash. i am a old bosch tech and alot of people dont add the jet dry properly. this is for drying,spots and-cleaning you must add the jet dry or rinse agent (same thing)into the compartment. close compartment,then lower and raise door 3 times,then fill again repeat until you cant add anymore then it is filled.if this help please send me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHY66C05: interlock broken, dishwasher rinse-aid leaks, and soap does not open (sometimes)
door lock is in the wrong position. open door and use 2 small screwdrivers to lever lock to correct position. bend the hook on the cabinet slightly downwards if it is a metal hook
rinse aid and detergent dispensors are 1 item. could well be faulty but can also be module. check you are getting volts to the solenoid at appropiate part of the cycle
Sep 06, 2008 | Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
112 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
