Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Booting problem i m unable to boot my pc ,my cd-rom is taking other data cds, but no response on bootable cd. plzzzzzzzzzzz help me.
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    are u trying to install xp?do u have two or more disc drives?is boot order set to boot from cd/dvd?
  • 3 Answers
Install MS Windows XP / 2003 / VISTA CD setup file (ISO file)
Then
  1. Start the computer with your chosen boot disk.
  2. Change to the cdrom drive.
  3. Go into the \i386 directory on the cdrom.
  4. Run WINNT.EXE to begin the install process.
Posted on Nov 21, 2008
Bootmgr is missing
Take one bootable windows cd rom , insert the cd rom in cd rom drive, restart your Laptop , go to bios setup and select boot from cd rom after then save and exit . your Laptop will boot from cd rom . it will take some time , when you will see action prompt , select R ( if your bootable windows cd rom is SP2 ) , select D ( if your bootable windows cd rom is SP3) . if you select R you will be prompt repair consoul , format C:\ then instal windows SP2 . if you select D , you will be prompt delite partition , delite partition C:\ after then select C to creat partition and install windows SP3. either of one windows install like that and problem will be solved. n.b. if you don,t have cd rom drive pls collect USB cd rom drive.
Jul 30, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a KBT Neo-V MS-7032 V 1.0 motherboard that has problems booting from newer CD/DVDs. Some older CDs will boot such as the XP Pro installation disk. However, my Acronis backup restore disk and my...
Hi
Whether a CD will boot or not really decided by th emotherboard, it is decided by the basic control program called BIOS. BIOS works in a simple way by, if set to boot from a CD or DVD, checks whether the disk is bootable and, if so, boots from it.
First ensure that the discs you are using are all bootable.
Bootable Backup Restore and Partition Manager disks only work if data partitions already exist on the hard drive.
Bootable operating system discs can boot whether there is any data or partitions on the hard drive or not.
Partition Manager software can be used inside windows, to create, delete, resize and copy existing partitions. In other words, install and run the program from your Windows desktop.
Look here for guidance on creating bootable CDs
http://www.whatsabyte.com/P1/create_cd.htm
I hope this helps.
Aug 26, 2011 | MSI K8T Neo-V (MS7032-020) Socket 754...
My pc is not booting so is their any solutions for that. i need instructions for making a bootable XP without nero. becoz i dint have a blank cd wih me right now, to write a cd
You can't boot Windows XP from a floppy disk the way you used to be able to with DOS. One handy way to easily boot XP is by using a USB flash drive. Here's how to make it work. Boot Windows XP from a USB flash drive
Aug 24, 2010 | Computers & Internet
UNABLE TO BOOT FROM WINDOWS XP
First Make sure your cd/dvd rom detected in bios.
For that First open cpu cabinet refix power cable and ide cable to harddisk.
Then check your bootable recovery disk and cd/dvd rom working fine.
When you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set first boot device as your cd/dvd rom then save settings and exit.
Then it boot with disk .
If still not boot then there may be some issue with cd/dvd rom or bootable disk.
Let me know if you need more assistance.
Thanks.
Oct 13, 2009 | Computers & Internet
Getting problem in formatting the IBM PC
check if the cable from the cd rom connected to your ibm pc if its ok , also check the master, slave configuration pins into the back of your cdrom. make sure that theres no conflict between the hard disk and the cdrom. Your cd rom may probably cannot be detected. make sure that it is working first. then install the hard disk. The hard disk must be in primary master and the cd rom must be in primary slave. then try booting it to your cd rom. also, try checking if your windows xp setup disk is bootable, it means that it can boot from cd rom. PM me if you have other experiences after doing what i adviced. Thank You.. heres my email. jmizpahadonai777@gmail.com
Aug 07, 2009 | IBM Thinkcentre 8185 PC Desktop
Where can I get a new DVD Cd for my sony pcv-v200g.
Hello
please check first the bios settings check the boot priority select the 1st boot priority to cd or dvd rom then exit and save while inserted the bootable cd..
Angel
Thanks..
Aug 02, 2009 | Sony VAIO PCV-V200G PC Desktop
Lenovo laptop not booting from any CD, But able to read other Cds
you can check by disabling all other driver to boot except from cd rom. if it fails again then try with a new bootable cd written in low speed, if still it fails then try with a new rom
Jun 25, 2009 | IBM Computers & Internet
.exe files got corrupted
well, if the CD won't read in Windows, and this is due to a virus, it should not affect the drives functionality before windows loads. You will need to use a bootable CD (like the Windows CD) and when you power on hte computer, enter the boot menu (check bottom of screen during power up for the correct button.) then select CD ROM and see if it will boot to Windows Set up. If it will, exit setup, restart windows, back up your data to a jump drive and then reboot with the CD & boot menu selection, and reload windows. Before you do any of this, go to acer's website and download all of the drivers for your computer to a jump drive, you will need them for the windows reinstall
Jan 08, 2009 | Microsoft Windows XP Professional With...
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Cd rom not working
Let’s determine if your CD-ROM drive or your Operating System Software ( ie...Windows XP) is the problem.
You will need a bootable CD, you can use your “Dell Resource” CD or any other bootable CD disk.
Power on the laptop and tap the F12 key to get to the “Boot Selection Menu”. Insert the DELL “Resource CD” into the CD-ROM drive. Select “Boot from CD/DVD drive” from the selection menu.
If the laptop boots from the CD drive then you Operating System Software is the problem.
If the laptop won’t boot from CD then your CD-ROM is defective and needs to be replaced.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell Inspiron 1501 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
