Question about GE Profile¿ 48" Built-In Stainless Side-by-Side Refrigerator with Electronic Dispenser, PSB48LSR
Ge profile built in SS refrigerator
Hi.  I have the common "fresh food freezing" problem.  I've order the new damper / fan assy, but need a diagram as to how to install it.  Where can I get that diagram?
thanks
gary
  • Anonymous Dec 16, 2008
    My food is freezing in refrigerator (ge profile)
  • 74 Answers
Go to www.geappliances.com - service and support section - parts and search for your model number . You will be able to get an exploded diagram in pdf format for each section of the appliance.
Graham
Posted on Nov 28, 2008
Ge gss25wgmd fresh food freezing
You will need to perform a refrigerator self diagnostic test found in the service manual found here=> GSS25WGMD Service Manual
Then go to page 48 of the service manual (Damper Door Not Opening or Not Closing) GE ARTICA PROFILE TECHNICAL INFORMATION This test will help you determine if the problem is the damper, temperature sensor or the control board. Doing these test are not for everyone and may require that you have someone that can perform diagnostics. If you have questions please let me know, Thanks Sea Breeze
Nov 29, 2012 | GE GSH22JFR Side by Side Refrigerator
Freezing fresh food
HI,
The problem is with the damper door.Check that it is not cracked.If it is cracked then you will have to replace it with a new one.
Goodluck..
May 17, 2008 | GE GTS20ICNCC / GTS20ICNWW Top Freezer...
Damper wont open
send the model number and also did you change the mother board in the back of the fridge,wr55x10942,check out this picture of the board,it tells you how to read out the damper,thermistors,defrost parts
http://www.flickr.com/photos/zenzoidman/4482598198/sizes/o/in/photostream/also check this out if you can't find your tech sheet down where the front kick panel is
http://fixitnow.com/wp/2010/01/17/ge-profile-pss25-refrigerator-freezing-everything-in-the-fresh-food-compartment-regardless-of-temperature-setting-and-the-water-dispenser-quit-working-too/
Jul 11, 2012 | GE Refrigerators
Temperature regulation not working (max only), water dispenser not working and ice maker not working although dispenser works
The symtoms sound all to common on GE units. Based on your symtoms I suspect the fresh food area is to cold. The damper assy is controled by the motherboard / thermistors. This damper assy adjusts to control the air movement from the freezer. During its cycling it can snap loose when this happens the air from the freezer is uncontroled. Within a few days the fresh food compartment temps can drop below freezing. The drop in temp also can freeze the water reservoir behind the lower crispers and in some cases the water filter. Altho You may have other issue (i.e. filter, bad fill valve assy, motherboard) the above statement happens 70% of the time. Fresh food damper assy part# WR49X10091 est $135.00.
Ric
Mar 09, 2010 | GE GSS25LGM Side by Side Refrigerator
Ge profile refrigerator PSS27SGNA BS....unit's refrigerated section keeps freezing food. even after we've adjusted the temp up to 36 or 37(recommended) it stays at 30 and keeps ruining the produce.
Check the air damper at the back top left of the fresh foods section to see if the damper door has broken and thus not able to close. It is electrically operated, but if it breaks, you can have your exact condition occuer.
Feb 03, 2010 | GE Profile¿ 26.5 Cu. Ft. Stainless...
My GE Model PSS25MGNAWW Artica Profile Refridgerator has begun freezing the contents of the bottom Sealed Pan and Fresh Produce Drawers. Put setting up to 2 and Chill Dial to Cold (left) but temp is stayng...
Freezing in cripsersG.E artica:
Models Affected: All 23 25 27 and 29 cubic foot electronic side-by-side refrigerator units with plastic Liners manufactured in 2001 or later. This includes all Profile- (Arctica and Eterna") models Consumers have called with reports of freezing in the Vegetable (middle) pan or the CustomCool M (bottom) pan , frozen water tank or frozen water filter.Freezing in the pans , a frozen water tank or a frozen water filter is caused by excessive airflow from the vents in the tower.
To eliminate these freezing issues , install kit WR49X10045. Follow the instructions included in the kit.
Damper door broken G.E artica:
Affects all 2001 models produced with "M" as the eight letters in the model i.e.: PSS25SGM with serial date code LA4 , MA4 , RA4 , SA4 , TA4 , VA4 , ZA4 & AD4. Freezing happens when damper door breaks leaving the unit with no control over the very cold air entering fresh food compartment from the freezer.
Replace damper door assy , with new damper door kit WR17X11508.
To verify the damper door is broken , remove the light shield and rear light bulb from the top of the refrigerator. Enter the factory diagnostic mode by pushing all four temperature control buttons at the same time. Perform damper motor test (FZ 1 , FF 0). Press any other button i.e. Custom cool or filter reset to start damper test cycle. Shine flashlight through right hand side opening of light assembly to view movement of damper door. To exit test mode (FZ 1 , FF 6). lf damper door assembly needs to be replaced , pull top two shelves out 2 ". Pull rear tower assembly slightly forward with both hands, move to the left and the right to expose the two screws that secure the duct assembly , also remove both screws that secure the duct to the ceiling. Replace with new damper motor assembly WR17X11508.
Dec 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Profile fridge side isn't staying cold, but the freezer is. There is no thick frost built up in back of the freezer side so I know it isn't the defrost heater. Could it be dirty coils underneath the...
There are a couple of things that can cause this. Thermistors, mainboard, fan and damper.
Start with the cheapest.
1. Check Thermistors - Pull J1 and check connector pins 1,2,3 and 4 to pin 5. They should beapproximately 15Kohms. In your case, the freezer thermistors (pin 3 and4 ) should be higher than the fresh food (pins 1 and 2).
2. Fan and Damper - Fresh food fan should be on and damper from freezer to fresh food should be open. If not, check that fans spin by hand and damper doesn't look damaged
3. At this point it is most likely the motherboard.
http://www.fixyourboard.com/techzone/refrigerators/ge_fridge_warm/warmflow.html
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile¿ 48" Built-In Stainless Side-by-Side Refrigerator with Electronic Dispenser, PSB48LSR Logo
186 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
