Question about Dewalt 18 Volt Compact Drill Kit
When i use the drill it smokes real bad where the batt. connects
I was putting up a shelf, trying to get a stubborn screw in the wall and the hammer drill XRP started to smoke when i set it down. Now everytime i push the lever (even just to open up the end to put the bit in)it starts to smoke.
What broke, can i fix it? and where do i get the parts from?
    Novelist:
  • 193 Answers
You have a short in your drill motor. I would not recommend using it as it is possible for the battery to explode.
DeWalt is probably the best made drill motor. I would look to sending it back to the factory for repairs. Run the internet for DeWalt and get a phone # to call them. You never know, this may be a problem the factory may fix for free.
Posted on Nov 22, 2008
I am having trouble removing the last drivers side screw on the manifold on a 1999 chevy express 1500
Exhaust manifold bolts are stubborn at times use a good penetrating oil let sit then use a hammer 2 lbs and tap head of bolt shocking the threads to loosen them up. then try tightening first then loosen if still stubborn soak again then repeat sometime with a wrench and applied torque to bolt while hitting it will loosen them. good luck drilling out broken bolts is a expert task. so time is on your side right now be patient.
Nov 07, 2013 | 1999 Chevrolet Express
I have a wooden shelf which I want to hang above my flat screen tv, what type of screws should I be using?
Depending on weight of shelf and contents.
And if you can hit a wood stud.
http://t0.gstatic.com/images?q=tbn:ANd9GcRgImEAL3MOBqQus1-EOz1kKhcNhWnCFnVcBrQtBZaGw0KC_bdPCw
I like the plastic zip-it anchor because it is pretty strong for towel rack or shelf with a few books etc, It simply drills flush into the wall and then you can use a regular pan-head or drywall screw to connect shelf to zip it. Later the zip it can unscrew and hole is filled easily.
Wall dog is nice for 1 step into drywall. Lightweight shelf, with 2 small books and vase..
Toggle bolt for heavy shelves, But requires good sized 1/2" hole drilled first, and takes a few skill techniques.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 13, 2013 | Woods Hardware & Accessories
Do you know how to put this tv bracket on the wall?
Yes you will need a stud finder and a drill . Find you're studs in the wall. Mark them. Then you're gonna want to locate we're you're gonna want you're tv. The height. Put you're mount up to the wall making sure the whole that will holding the screws that go into the wall are over you're studs. Get a marker mark the wholes. Then get you're drill and drill in you're screws. If the screw are real thick then I would juggest drilling pre holes this way you're studs do not crack
Nov 01, 2012 | Televison & Video
DCD 950, How do you remove the chuck
open up the jaws ,look in the now open area there is a standard screw at the base remove it chuck will come off ,,some are stubborn,,
Jul 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Chuck jaws on Makita 8444D fell out
There is suppose to be a flat head Left hand thread chuck screw in there. It may have fallen out. You will not be able to put the jaws back into the chuck. You will have to replace the chuck with a new one. If you make sure that the chuck screw is not there you can remove the chuck with a couple of steps. Make sure the drill is in it's lowest gear. Use a strap wrench or some large vise grips on the chuck. If there is still one jaw in the chuck make sure it is all the way open and locking the collar to the chuck. The chuck will come off in the regular lefty loosey configuration. It may be stubborn. If this is the case, You may have to cut the collar off the chuck and use a pipe wrench. Or bring it to a professional to get it changed out.
Sep 23, 2009 | Makita 18 Volt Cordless Hammer Drill Kit ...
Both cordless drill batteries dead.
Your battery could say its good by just testing voltage,but when a load is put on it , its a different story. My dewalt batt. did the same thing I opened up the batt. case and there was 12 "C" sized batteries inside linked together with little metal strips. I bought 12 rechargeable "C" batts. and carefully drilled where the metal strips are soldered, changed out batt. and re solder. It's been over a year now and still drilling . Also you should do this one batt. at a time so you don't put one in the wrong order .
Mar 17, 2009 | Craftsman Drills
Chuck broke on my hammer drill
To take a chuck off of your drill open it up all the way.
Inside there's a screw that you have to take out. It has to be turned clockwise to get it out.
You may need to struggle with it a bit because it's usually really on there tight.
Some folks even use a second drill to loosen it up and that's a really good idea if you have access to one.
Once you get the stubborn little screw out, put an Allen wrench in the spot where the bit would fit in.
If you can't turn it--and you probably won't be able to--then try using a rubber mallet to (gently) hit the arm of the Allen wrench to get it to turn.
Then you should be able to just take it out.
Put the new chuck into the drill.
Add a few twists of the Allen wrench in the opposite direction.
Tighten it up good.
Put the screw back in place and also tighten that up good.
The drill has a lot of vibration and if these aren't tight, it'll cause problems down the road.
Your drill, expertly fitted with your brand new chuck, should now be good to go.
Please rate this solution
Dec 19, 2008 | Drills
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Chuck change
After removing the screw and inserting the allen wrench shift the drill to the LOW position and turn the clutch to the drill only position. Use an allen wrench about the size of the chuck capacity so that it will not flex when hitting it with a mallet. Sometimes they are stubborn because of the torque but this should work. Put the allen wrench at about a 30deg angle and hit the wrench. I support the chuck on a workbench or a block of wood will do fine. The chuck has standard threads.
May 10, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Dewalt 18 Volt Compact Drill Kit Logo
317 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
