Question about 2wire 2700HG-B Router (2700HGB)
2wire 2700HGV cannot detect wireless Linksys IP camera WVC54GC
I recently upgraded my services and was provided with a 2wire router. The problem is that the 2Wire is unable to detect my Linksys IP camera wireless after installation. I was using a Linksys WRT54G router prior to the upgrade and it works just fine. I have contacted my ISP and was referred to the local vendor for 2Wire and was told that they cannot do anything about it! Do you have any suggestion? Thanks!
  • a_yunos Nov 22, 2008
    The Linksys IP camera works fine with the 2Wire 2700HGV when its connected with cable but does not work when its detach(suppose to work wireless).
  • Carl Navarro
    Carl Navarro May 11, 2010
    Take a hammer and smash the box and call your ISP again. :-)
I have the same setup and I can tell its a pain. I chose pain over money, since I'm just a poor guy. I just assigned the Linksys IP camera the available IP address from the 2wire router along with the subnet and gateway, usually gateway.2wire.net. With a little bit of patience 2wire gave up and accepted the settings and even made the Linksys IP cam as a static IP in the address assignment. 2wire sucks, I can't wait to finish my contract with my ISP and go back to where I used to use my linksys router,
Posted on Jun 03, 2009
  • 120 Answers
Purchase a different router and return the 2wire to the ISP explaining it is not compatible with your equipment at home. You may need to provide them with the new router's MAC address.
Posted on Nov 21, 2008
Is the 2wire gateway 2700hgv-b2 a wireless router
Yes it is...
check this site to confirm: http://www.pcwintech.com/screenshots-2wire-2700hgv-b2-sasktel-firmware
if you have further more query in terms on configuration you can leave a message:
for configuration you can also try visiting this site: http://support.2wire.com/?page=view&article=170&text=2wire%20gateway%202700hgv-b2&cat=1&sort=
four thumbs up as a rating will be highly appreciated
Thanks, Roger
Jul 31, 2011 | 2wire 2700HG-B Router (2700HGB)
What is the default wifi password for my 2wire 2700HGV-B2 modem?
2wire wireless network key
The network key is located at the side of the router you will see a barcode on it. It indicated the wireless network key.
If you have questions please let me know. Thanks
Jul 05, 2011 | 2wire 2700HG-B Router (2700HGB)
For 2wire HomePortal® 1800HW. adaptor broadband connection ... I recently upgraded from my 2wire DSL to Uverse. ... Linksys wireless adapter won't auto connect to 2Wire. ... I thought to use it as a...
First thing to do here is to reset the unit by pressing the reset button for 30 seconds while power is ON , after that if still the same better to contact your ISP or the manufacturer of the device and have it replace..
Sep 08, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
Wireless not working
remove wireless security as Linksys won't accept certain WEP keys
ping the device to determine that it is there. This often works and shows it is a Linksys setup problem. If can't even ping the device then you have another bigger problem.
Finally, move the camera to under 5 feet of the wireless access point and then Setup will work. After setup then you can move camera out further.
Apr 11, 2009 | Linksys Wireless-G WVC54GC Network Camera
first of all let's start from the complete facts, does your 2wire router have built in wireless or no? how you did the the cable connections between tht routers?.
Apr 04, 2009 | 2wire HomePortal® 1800HW Router...
2wire 2700hg-b wired router wont allow setup of Linksys WAP54G access point
the ip address of the 2wire router might be different from the ip address being used by the wap54g (ip address is 192.168.1.245 by default) that's why it's not being detected.
you need to directly connect the wap54g to a computer and set the computer to use a static ip address (ex. 192.168.1.240) and run the cd that came with the wap54g. you need to set the ip address of the wap54g to the same segment being used by your router to make them see each other
hope this'll help you and just ask me if you have other concern
ciao!
Aug 24, 2008 | 2wire 2700HG-B Router (2700HGB)
Win98, Linksys USB Adapter, 2wire router... no internet
hi!
sorry if it took a while to get an answer to your question...
anyway, let's begin by ensuring that you have completed installing the drivers & software of your wireless adapter.
launch the linksys wireless program by clicking on the icon for the linksys on the system tray or generally, this can also be launched from the programs menu after clicking on the windows start button.
on the main screen for the linksys, there are 3 tabs: link information, site survey & profiles. select the profiles tab
on the profiles screen, click on the new button to create a new profile. name the profile with a customized ID & click ok.
under choose a net type, select infrastructure mode. enter the SSID (this is your customized ID created on the new profile) & click next.
under network setting select obtain an IP address automatically (DHCP) & click on next.
under security settings choose "disabled" for WEP and leave the rest of the fields blank.
confirm the settings by clicking on yes.
note: you don't need a driver for your 2wire router, ensuring that the 2wire is already working with the ethernet connection.
also make sure you are able to see your devices on the mdc page, go to homeportal/management, local network> device list.
i assume that the mac g4 is able to connect wirelessly to this 2wire modem, am i correct?
please let me know if you have any issues... we'll work this one out, ok?
Apr 16, 2008 | 2wire (1000-400108-001) Router
Linksys camera wvc54gc
make wsure that that port 1024 is assigned to the ip address of the camera under port forwarding, you can also try changing the remote port, try 5000 and above, if it still does not work try DMZ.
you can always check if port 1024 is open on your router by performing a port scan through the net, you can get a free port scanner on this site..
www.t1shopper.com
for the process on doing fort forwarding on your 2wire router check this link.
http://portforward.com/routers.htm
Mar 15, 2008 | 2wire 1800HG Router (RG1800HG00)
Camera setup
Check your advanced wireless settings on your router, wireless mac filter might be enabled. Tou must allow the mac address of the wireless camera.
Good Day
Feb 24, 2008 | Linksys Wireless-G WVC54GC Network Camera
2wire 2700HG-B Router (2700HGB) Logo
1,197 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
