Question about HP Photosmart 2710 All-In-One InkJet Printer
HP Photosmart 2710 All-In-One InkJet Printer Problem
My old cartridge carrier had a hole in the plastic "circuit board" so I got a new carrier and need to know what to remove and how to remove it so I can install the new one. Any help would be greatly appreciated!
I need to get into a chat with a service tech
Posted on Feb 15, 2009
  • skittilson Feb 15, 2009
    waiting for connection with computer technician
Tip
My 2710 All In One keeps giving an error message that the printer cartridges are...
Is your cartridge clogged,,,
Then in the maintenance settings in PRINTERS AND FAXES,, do a deep ink cleaning,,
If that fails then blot the cartridge on a piece of tissue damped with alcohol.. or let the cartridge sit in some rubbing alcohol for a cpl or minutes and then blot it..
As a last resort if the above fails,,, WARNING NOT A CONVENTIONAL METHOD
try boiling the cartridge for a few minutes,, MAKE SURE THE WATER IS BOILING BEFORE U PUT THE CARTRIDGE in.. so to to remove most of the air from the water to prevent corrosion
on Dec 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My HP Photosmart 2710 All In One Printer has the following error: "Remove and check cartridge on right". I have removed cartridge, restarted the printer and my computer. Nothing seems to get...
Is this a new HP cartridge and the correct one for your printer? If it is a refilled cartridge, try replacing with a brand new HP cartridge.
Next try cleaning the contacts on the cartridge and the cartridge carrier. (While you are at it, make sure that there is no left over tape on the cartridge or other issues blocking the cartridge) To clean have distilled water and lint free clothes available. Bottled water and coffee filters will work. Tap water is not a good choice for this. With the printer on, open the printer cover and wait for the unit to stop moving the carriage. Remove the right cartridge and then unplug the printer. Then dampen your first cloth (wring out any excess water with your fingers), wipe the electrical contacts until no excess ink or any dirt remains. Do not touch the ink nozzles.
With another damp cloth, wipe the contacts in the cartridge carrier.
Either let everything sit for 10 minutes or dry with another lint free cloth. Reinsert the cartridge, making sure that the cartridge is fully seated in the carrier. Then plug in the printer. Finally close the printer cover.
Check if your error persists. If it does, try cleaning the contacts again. If the error repeats again, try a new cartridge if you haven't yet done this step. If a new cartridge fails to solve the problem, check if the cartridge is under warranty. If it is, contact HP.
One option is to try printing with the right hand cartridge removed. This will provide grey-scale documents if black is left in. If you only have the color cartridge in place, your pictures may look odd.
I hope this helps.
May 10, 2011 | HP Photosmart 2710 All-In-One InkJet...
HP 339 ink cartridge is not supported
Hello
For HP 2710, you need HP 96 and 97 number ink cartridge, 339 is not compatible with this printer.
Hope this helps
Jan 28, 2011 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 Scaning software
The software for the HP Photosmart 2710 All-In-One InkJet Printer can be found at
http://www.hp.com/#Product
After arriving at the site, click on the subheading "Support & Drivers", then follow the 2 steps
listed to obtain the needed software.
Jan 22, 2011 | HP Photosmart 2710 All-In-One InkJet...
The printer is telling me to replace the color print cartridge. I only want to print in black. i have a hp photosmart 2710
Your only problem here is that you own a HP inkjet printer.  This printer uses up both cartridges even if you print in black.  Donate this thing and get you a Brother laser printer that just prints in black.  This will cost less to operate per page and uses less energy.
Oct 25, 2009 | HP Photosmart 2710 All-In-One InkJet...
I was printing a document when the printer stopped and this error popped up on the printers LCD (hp photosmart 2710) ''remove and check right ink cartridge'' how do I fix it?
1. your rt side ink cartridge is damaged change it with compatible or new cartridge to get rid from this error.
2. or try ones cleaning the cartridge with dry cloth.
Jun 10, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hp photosmart 2710
sounds like there's something stuck under the cartridge, or the 'compatibility' is suspect..that's the only reason that happens, a mechanical mismatch
Mar 09, 2008 | HP Photosmart 2710 All-In-One InkJet...
Plastic guide strip behind cartridge assembly broken
It can be bought from a service center, it's called "Encoder" or "Position Encoder".
To make sure it's the encoder, if you turn the printer ON it will say that the carriage is blocked or will flash the lights showing that problem.
Feb 06, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 All-In-One InkJet Printer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
