Question about Brother Office Equipment & Supplies
My 1200p fax machine only prints half a page - Brother Office Equipment & Supplies
  • 25 Answers
This is a ribon transfer problem. Open the machine and see if the ribon has been mouving properly or fixi it inside the cartridge. GOOD LUCK.
Posted on Nov 21, 2008
Incoming faxes stuck in memory, how do I print them. Prior to this the faxes were coming through, but half printing then jamming, so press start and that peice of paper would come out then the next go in...
This answer maybe a little late for you but for anyone else tring to print fax stored in memory:
1. Press Menu - Fax Functions will display
2. Press 2 - Print report will display
3. Press Enter - Last Transact will display
4. Press 7 - Reprint Faxes will display printed the pages
5. Press Enter
This will print all faxes in memory. Press Stop when you have printed the pages you need.
You can print fax log (Press 2 after step 3) to see what is in memory
Oct 01, 2009 | HP 1020 Plain Paper Thermal transfer Fax
My machine print but half of the page be very dark
Open front cover remove the drum unit.
On top over the drum unit there is a blue or green slide lever.
Move the slide lever back & fourth 20 times
Make shuer the lever is all the way toone side.
Reinstall drum.
See how this works.
If not. Remove drum.
Remove the toner cart. from drum
If you have some canned air or a air compresser
Blow out the drum unit
( DO THIS OUT SIDE YOU WILL HAVE TONER ALL OVER )
Redo the slide thing.
Reinstall toner & drum
Make a copie also do a report see if any differance in the print
Hope this works
Apr 09, 2009 | Brother IntelliFAX 4100 Laser Fax
RECEIVED FAXES AND/OR COPIES PRINT ONLY HALF PAGE
Don't know that machine all that well, but it sounds like the laser filter glass may be dirty, or the laser unit. It seldom happens, but did you by any chance blow it out with compressed air?
Anyway, you may try taking out the toner cartridge, and if you tilt the machine upward you should see a sort of 'filter glass" above where the cartridge sits that allows the laser light to pass through from above. try cleaning this with a cloth, and hopefully that will solve your problem.
Mar 09, 2009 | Canon FAXPHONE L80 Laser
Incoming fax shows one half of the page
The Thermal printhead is most likely burned out on one side and will need replaced. It could also be the printhead connector has worked loose and is only making partial contact. Remove the connector and reinstall. If that doesn't solve the problem then it would be cheaper to purchase another fax.
Jan 22, 2009 | Sharp UX 108 Roll paper Thermal Fax
Sharp Inkjet UX A 1000
I had the same problem and, like you, went to the internet to find a solution. One answer I found was to unplug the vax, wait one minute and then replug it. This didn't solve the problem for me. Out of desperation, I printed the fax "Help" pagea nd, lo and behold, after it printed my Sharp 510 Fax was back to normal.
Nov 04, 2008 | Sharp INKJET FAX UX-A1000
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother MFC 1750 fax prints only left half of page. New print cartridge does not help.
I would check to see if the metal connections between the print cartridge and the machine are clean, wipe them off with a clean cloth even if they look good.
See if that helps at all
Apr 23, 2008 | Office Equipment & Supplies
Phillips magic 3 fax machine
in this situation i advice you to refil ink jet because ink consumption depends on the size of black area in the document and high black area will absorb the ink.
Mar 06, 2008 | Office Equipment & Supplies
Printing and sending
It sounds like you have a bad scanner. Depending on the age of the machine it may be under warrany. Even if it is not, I would call Brother and complain. I know in the past, they did have some scanner issues that they wewre covering even past the warranty period. Their number is 1-800-284-4357. Good luck John
Sep 06, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Problem with printing...
First and most important with Brother machines is , you need to use genuine brother supplies. Almost every time I service a brother and I find generic toner and drums cause the print quality issues. New supplies cost as much as a new machine. If not the supplies then it is laser or power supply.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 06, 2007 | Brother IntelliFAX 2800 Laser Fax
196 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
