Question about Lands Phones
I have a model kx-tg6071 phone set (4) that I can not get out of mute mode. I have unplugged the wall unit as well as the phone line and hooked them back up,but it didn't solve the problem. mgmoore@mcn.net
  • mgmoore Nov 25, 2008
    None of your suggestions worked. I finally had to buy a new phone. Pretty bad for a phone only 9 mos. old, huh? Didn't buy a Panasonic this time! mgmoore@mcn.net
4 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: Panasonic Phones are on mute and will not work
The following is generic for most cordless phones:
Did you check to make sure that the phone is not in the intercom mode? If this phone has a base station speaker phone, make sure it is not on mute. Some of these phones have a fax connection. Make sure your phone line is not accidently pluged in to the fax section. Also if the phone has a fax monitoring feature check the the setup menu that the fax is not enabled. If the phone has an answering machine mode, make sure that this feature is turned off.
In the worse case:
There may be a defect in the X-Mit section of the phone. I would suspect the fault to be in the base.
Jerry G.
Posted on Apr 13, 2008
SOURCE: Phnoe and Answering System Inoperative - E1 flashing
I read about this, and while you were gone, if your power went out, try unplugging the batteries from the back of both phones for a few minutes & put them back in..I hope this helps!
Posted on Jul 03, 2008
SOURCE: base unit line 1 is flashing no dial tone
We followed your instructions and are not sure what worked, however, this AM phone line is working.
Posted on Sep 30, 2008
How can i set time and date in panasonic KX-T7730. Can ant 1 help me
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
password ( default is 1234).
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
Apr 07, 2010 | Panasonic KX-T7730 Corded Phone
How do I change the time on a KX-T7730 phone?
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
Enter the year.
button.
day.
Set the time.
are done.
Mar 29, 2010 | Panasonic KX-T7730 Corded Phone
How to set the clock at a panasonic kx-t7730
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
are done.
Mar 27, 2010 | Panasonic KX-T7730 Corded Phone
KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
4. Press AUTO DIAL / STORE to save your changes.
5. Press PROGRAM to exit program mode and you are done.
Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
HOW TO SET THE TIME KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( usaully default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Mar 14, 2010 | Panasonic KX-T7630 Corded Phone
Cannot adjust the date on the phone
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
are done.
Dec 29, 2009 | Panasonic KX-T7730 Corded Phone
Cannot reset the time and date on the phone
SHORT WAY:
(usually ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
are done.
Nov 25, 2009 | Panasonic KX-T7730 Corded Phone
How can I change the time on my KX-T7730 phone
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
6. Press PROGRAM to exit program mode and congratualations - you are done.
Nov 17, 2009 | Panasonic KX-T7730 Corded Phone
How can I change the time/date in the LCD Display in KX-7730 THX~
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
Enter the year.
button.
day.
Set the time.
are done.
Jun 18, 2008 | Panasonic KX-T7730 Corded Phone
In the worse case:
Jerry G.
Apr 09, 2008 | Panasonic KX-TG5632 Phone
Lands Phones Logo
29 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
