Question about HP Cameras
THE BATTERY IN MY HP PHOTOSMART R8 17 CAMERA HAS GONE DEAD AND WILL NOT TAKE A CHARGE. I HAVE NOT BEEN ABLE TO GET THE APPROPRIATE SIZE BATTERY TO SEE IF THE CAMERA WILL THEN WORK BUT IT MAY WELL BE THE CAMERA ITSELF WHICH IS AT FAULT. HELP PLEASE.
  • kerrgeoff Nov 22, 2008
    I don't have a voltmeter, but in any case my camera is going to need repairing. Where can I get this done in the U.K.?
    Master:
    Sergeant:
  • 461 Answers
If you need a repair I suggest you contact HP service center near by. I suggest you check below link to get details
http://welcome.hp.com/gms/uk/en/contact_us.html
should you have other technical issue you may want to read below link
http://etech.maiila.com
good luck
Posted on Nov 22, 2008
  • HP Master
  • 19,396 Answers
    Guru:
  • 859 Answers
There are several courteous people willing to help you with your battery problem. The most sensible place to go to is your local camera store, the one where the hobbyist go to and has brand name ads in the yellow pages.
The people at this type of store are more than capable of not only testing and replacing your battery but also giving your camera a fast look over for some obvious, to them, issues that may be draining your battery too quickly. And, should you need a charger that's failing and the cause of all this trouble, they can test it and get you a replacement.
Regards,
Worldvet
Posted on Nov 21, 2008
  • 10,515 Answers
Follow the steps below to resolve this issue: Step one: Reset the camera
  1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
  2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
  3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
  4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
  • If the is not resolved , continue with the next step.
Step two: Check for damage or corrosion on the batteries
  1. Open the Battery/Memory card door on the camera.
  2. Remove the batteries.
  3. If the batteries are damaged or show corrosion, replace the batteries.
Step three: Recharge the batteries
  1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
  2. Try turning the camera on after the batteries are fully charged or have been replaced.
Step four: Ensure the batteries are installed correctly
  1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
  2. Try turning the camera on.
Step five: Turn on the camera without the memory card
  2. Remove the batteries and optional memory card from the camera.
  3. Wait 15 seconds.
  4. Re-insert the batteries into the camera, but not the memory card.
  5. Try turning the camera on.
    • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
    WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
Step six: Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
  • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
  • Corrupt images on the memory card
  • More than 300 pictures on a memory card
  • Damaged batteries
  • Dead batteries
  • Incorrectly installed batteries
  • Damaged camera
  • HP Master
  • 4,806 Answers
Without a battery your never going to know, try plug the camera to the pc to see if the pc can power it and pick up the removable device (camera card) if id does the camera works.
have a look here for a replacement:
http://www.amazon.co.uk/s/?ie=UTF8&keywords=hp+photosmart+battery&tag=googhydr-21&index=aps&hvadid=3397194695&ref=pd_sl_4zanqxudn5_b
hope this helps
regards
  • 586 Answers
    You can check your battery from any volt meter but if your camra is dead then there must be fault in your camera first check your battery from volt meter and then do any thing els.
    Thanks.
  • AMJAD HUSSAIN Nov 23, 2008
        Please see the link below along with help line.
       Contact Details HP www.hp.com/support 1-800-474-6836 (1-800 HP invent)
     or Visit
    http://www.hp.com/hpinfo/newsroom/press_...
    Thanks
    Sergeant:
  • 276 Answers
U can get the proper battery at radio shack website.
  • smarttech Nov 21, 2008
    mostly replacing the battery solves the problem.as the battery is completely dead so the ccamera is not getting the required power to get on.if still after replacing the battery the camera shows some other problem let us know to help you further from there.
    http://www.radioshack.com/home/index.jsp
    just click this above link and order a appropriate battery online. they will provide you.
HP photosmart 725 battery is not charging
This camera takes a lithium battery and if it is left to fully discharge then you may never be able to charge it up again. Your answer may be another battery. Find a cheap third party battery to try it out.
Feb 22, 2015 | HP Photosmart R725 6.2 Mp 3x Optical Zoom...
Can I charge my HP 632 (that has rechargeable batteries in it; from the USB hooked to a solar charger?
You may recharge the batteries using any compatible charger. It doesn't matter to the camera whether the charger is powered by a nuclear reactor or a hamster running in a wheel. Bear in mind that the HP M632 is NOT a battery charger. The batteries must be recharged outside the camera.
Dec 12, 2012 | HP Photosmart M632 Digital Camera
Hp photosmart M23: can I charge new batteries in the camera
The batteries can be recharged in the camera with the appropriate adapter or dock. See page 155 of the manual.
Oct 17, 2012 | Cameras
How to charge when battery already dead
The Kidizoom is a camera, not a battery charger. If you wan to use rechargeable batteries, you'll have to charge those batteries in a separate, appropriate charger.
If by "dead" you mean a broken, defective, or past end of life battery, then there is nothing you can do to charge it again. If you simply mean a completely drained battery, put it into an appropriate charger and charge it following the instructions for that charger.
NEVER try to charge a non-rechargeable battery.
Jan 22, 2011 | Vtech Kidizoom Digital Camera
Camera doesn't seem to accept a charge Camera
Yes. You need a new battery. I would assume the same. Have the battery checked or try charging it in the battery charging cradle overnight.
Dec 13, 2010 | HP Photosmart R727 Digital Camera
HP R717 camera will not work . installed new battery will not charge
Connect the camera to the charger. If it works, while connected to the charger, the problem is either with the battery or the battery contacts. Make sure that battery contacts are clean.
Apr 23, 2009 | HP Photosmart R707 Digital Camera
Camera turns off
Are you sure the battery is holding a charge? you can get one off of ebay pretty cheap. Just to check. It is acting like a battery issue but it could be a damaged lens that can cause the same out come. I hope this helps lead you to a easy repair.
Mar 28, 2008 | HP Photosmart R927 Digital Camera
Non functioning camera
Whoah, the same thing happened to my camera.
I'm going to get a new battery. I hope it works...other wise it is just a dead camera and you need to look into getting another one *gulp* how long have you had it??? Mine I bought in mid year 2006. And this is the 2nd time its gone dead. The 1st time, I just had to take the battery out and put it back in and it turned on immediately. But this 2nd time, I tried the same technique and NADA.
If it doesn't work then I'll end up buying a HP photosmart, Sony or Kodak (recommended).
Dec 13, 2007 | Optimus DS-5080 Digital Camera
Cameras Logo
15 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
